WLC2106 DHCP problem.
java70
Community Member
Hi, all
I have a problem with DHCP IP distrbution.
My wireless environment is WLC2106 + 6 LAPs(1131AG).
The symptom is that WLC sometimes distributes duplicated IP addresses to clients, so WLC have wrong ARP tables.
Eventually, some clients which have duplicated IP addresses can't communicate with WLC and others as well.
Does anybody know how to solve this problem? (I think it's one of WLC bugs)
If so, please let me know.
Oh, I also have a log message relevant to this problem.
I attache the log message below
firmware version 4.2.61.0 "[WARNING] dtl_arp.c 1656: Unable to delete ARP mapping."
firmware version 5.2.178.0 "%DTL-4-ARPMAP_DEL_FAILED: dtl_arp.c:1818 00:40:ffffff96:ffffffae:38:fffffffe 10.1.31.66 Unable to delete ARP mappingIP belongs to 00:40:96:ae:49:18"
P.S : all of my clients use Cisco wireless interface card(CB21AB) and also use ADU(Aironet Desktop Utility).
I use only internal WCL DHCP server on this subnet, so there is nothing to affect it working wrong.
Thanks.
8 Replies 8
Leo Laohoo
Are you sure you don't have two (or more) DHCP servers dishing out the same IP Subnet range?
Disable the DHCP details from your WLC and see if duplicate IP Address is still ongoing.
I'm sure that I don't have any DHCP server on the WCL subnet expect for WLC internal DHCP server.
When this problem happend, I rebooted all my wireless devices(WLC, 6APs) while client already associated to APs.
When the devices perfectly came up, I found that some clients have duplicate IP address. so I removed the wireless interface card which belong to duplicate ip client and insert it again.
from that piont, the client got a new IP again from WLC DHCP server.
I assume that ADU(Aironet Desktop Utility) have some special mechanism like retaining IP address for ramdom time
If this kind of the mechanism exsist, this problem makes sence because when WCL finish a rebooting process and it comes up, All WLC DHCP table(such as lease time table) is cleared.
So it could be possible WLC gives clients duplicate IP Because the WLC doesn't have any infomation about which IPs are already given.
What do you think about it?
Leo Laohoo
I'm using CB21AB card and I don't experience this problem.
you also use ADU ?
Leo Laohoo
Yes. I am also using ADU v4.4.
Im curious what is your lease times?
Lease time is default value 24hours.
thanks.
It's really hard to find the cause.
After a quick look it looks like this is a known issue with the internal DHCP server. After a WLC reboot, the internal server clears it's lease history which may result in duplicates being given out.
So, I would say either use an external DHCP server, or open a TAC case.
