WLC2112 with Guest / Web-Auth and vlan
Kthorsted
I'm trying to configure my WLC with guest SSID and vlan 10.
The security is only set to Web-auth, and it is all working if the guest network is set to nativ vlan (1) But it seems that the http(s)://1.1.1.1/login.html is not reacheble from the guest SSID/VLAN??
Please help.
Management IP Address 192.168.14.252
Software Version 6.0.182.0
Emergency Image Version
I have tried with ver. 5.2 also -
I think that 1.1.1.1 is only reachable from a wireless client during webauth. They should not be able to reach that address once they have passed through the web auth page.
Don't know if that helps, or not.
I think you are right.
But the issue is that i don't get the login page - it tries to redirect but no answer from 1.1.1.1 and therefore no web auth... :(
