WLC2500 problem
joyride_us2
Level 4
Level 4
Hi!
I have an issue with my WLC2504 box. After some manipulation of the box :
- I cannot reset the config : it comes back to the config I had set in
- I cannot use the Console port any longer (?)
- the only way to access the console mode I have, is through the AP 1832I console port...but the controller does not accept the administrator password. Dead!
Let's start there!
Jeff
M. Wisely
Level 9
Level 9
Connect to the console port reboot the controller. Shortly after it starts booting you'll be prompted to hit esc to enter a boot menu. Hit esc and you will be prompted to select an option, one of this is Clear configuration.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/2500/quick/guide/ctr2504-qs.html
