WLC2504 low speed
3dtgnt_ljm
Hi All ,
our company has a wlc2504 with 8 1602i APs connected to a Gig switch, but client has a poor speed when they copy files. normally only 256kb/s , I tried changed one ap as fat mode, it more faster than other thin APs, 1.2Mb/s downloading on a 100M switch. I turned off 5G left 2.4G but no effect. and today morning I upgraded wlc's ios from 7.4 to 8.0 but downloading speed no changed. is it a bug for this wlc ?
Leo Laohoo
100 Mbps switch????  Can you check the switchport interface between the WLC and the switch?   Can you also check the UPLINK of the same switch?
Your description sounds more like a LAN issue than a WLAN issue.
