WLC5508 and 3rd party SSL cert
ALIAOF_
Level 6
Level 6
I'm looking to upgrade the code on the Cisco 5508 WLC from 7.4 to 7.6.  It has 3rd party SSL cert installed on it.  Anyone know if I'll need to re install that cert after the upgrade or no?
Scott Fella
You should not have to reinstall the certificate once it has been installed.  It's always nice to keep the certificate however in case you have a new controller or an RMA.
-Scott
-Scott
Scott Fella
-Scott
-Scott
Thank you Scott.
