11-25-2024 05:14 AM
Does WLC 5520 enable GTK/PTK Rotate Key by Default ? Can we disable or just only change key interval by command show advance eap
11-25-2024 05:23 AM - edited 11-25-2024 05:25 AM
You can change the interval
config advanced eap bcast-key-interval
Enter the number of seconds between 120 and 86400
I dont believe it allows disable as it would represent a seriously security flaw
11-25-2024 05:25 AM
Can I disable GTK/PTK Rotate Key on WLC5520
11-25-2024 05:37 AM - edited 11-25-2024 05:47 AM
From GUI of wlc55xx
""From the WPA gtk-randomize State drop-down list, choose Enable or Disable to configure the Wi-Fi Protected Access (WPA) group temporal key (GTK) randomize state.""
MHM
11-25-2024 05:40 AM
I dont believe you can as it would represent a huge security flaw. Key rotation is an important security mechanism in order to avoid unauthorized access. With fix key, it would increase the chances a hacker breaking in by sniffing your traffic.
11-25-2024 05:45 AM
If I want to enable Key rotation , How I can config on WLC5520
11-25-2024 06:05 AM
Key totation is enabled by default so, it is enable already in your WLC. What you can do is change the frequence of the key rotation with the command
If you use 86400 means one day.
11-25-2024 06:29 AM
Does WPA2-Personal also enable Key Rotation by default or need to WPA gtk-randomize State ?
How change the frequence of the key rotation for WPA2-Personal ?
11-25-2024 06:46 AM
It is the same for any kind of WPA. As you can see on the command, it does not specify which kind of WPA you need to use.
