WLSE Help
harris.h
Level 3
Level 3
We are currently implementing a full SWAN Architecture in our Organisation.
As part of our business we have around 150 small ADSL sites running off Cisco 837 Routers.
What I would like to know; if we replace these routers with 877 Wireless/Routers, how can we track rogues, etc., if they are not supported by the WLSE.
Any advice would be appreciated.
mchin345
Level 11
Level 11
The following link gives you the information about the Cisco 877 products.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet0900aecd8028a976.html
dcavanaugh
Level 3
Level 3
My advice is to hold off on the 870 series routers if you require wireless management. The reason the 870 routers aren't supported is because the router/AP doesn't run the WDS service which is required for WLSE management. I currently run a 871 with the integrated wireless shut down because of the lack of management built in. Hopefully this is just an IOS upgrade soon.
