WLSE Radio Scan Problems
jmiller
I have recently set up WDS at a remote campus. I scheduled a radio scan for 4:00am so as not to interfere with active users. The scan completed but not successfully. I got an error message regarding the WDS and I can not determine the reason. I have attached the Job Log from the WLSE.
All the AP's are registered with the WDS AP. The WDS AP is dedicated with the radio turned off. The WDS is in an authenticated state with the WNM. I'm not sure what the problem could be.
smahbub
Level 6
Level 6
Look like a bug - CSCed08559
Thanks for the feedback. However I'm running 12.3(8)JA2 and the bug applies to v12.2. I'm working with TAC to resolve. When I have resolution I will update the question.
jmiller
This has been successfully resolved with the help of TAC. The issue is actually a bug in the ACS v3.3.3. The bug ID is CSCsb47726. Once I applied the patch (replacement of a specific dll) the WDS and ACS and WLSE completely authenticated to one another.
