WLSE
sureshkumar.a
Community Member
we have cisco AP1131Ag which is managing through wlse1030(2.13).the wlse is showing the below fault on this access point account.Ap ios 12.4(10b)ja3.
Inconsistent device state found: Device "(divicename)": ifIndex=2, MAC=00-1e-7a-32-b3-70: "CISCO-DOT11-IF-MIB cd11IfStationConfigTable.cd11IfStationRole must be in the range [1..11] (was 0)"
pls help me to resolve this issue
regards,
subash
amritpatek
Level 11
Level 11
To resolve an inconsistent configuration, there are several actions to try:
It is possible that the most recent inventory failed for the device.
If the inventory is re-run, the condition may clear.
If the configuration value contested is user-editable, the problem can be corrected with the WLSE templates, the AP or BR GUI, or the AP or BR Command Line Interface (CLI).
If the configuration value contested is not user-editable, this is probably a Cisco IOS® error. In this case, the affected AP or BR must be upgraded to the most recent version of Cisco IOS.
