WMM on Cisco WLAN
cristian.munoz
Level 4
Level 4
Hello All
Please your help. What is the requirement for the endpionts if I enable WMM on Cisco WLC and AP?. What happens if a laptop, tablet or cell phone do not support WMM?
TIA
Cristian
 Nothing happens if you keep it as allowed.
If you configure as required , first check the  device datasheet to make sure it supports.
WMM
Enable WMM on a WLAN in order to create the simplest implementation of QoS; this option is on the QoS tab in the WLAN configuration menu. Other WMM policy settings are:
  • Disabled - WMM is not in use on the WLAN.
  • Required - Clients must support WMM or they are not permitted to access the WLAN.
  • Allowed - Clients that support WMM may use it, while those that do not support WMM can still connect to the network. "
