workgroup bridge in cisco unified wireless infrastructure
rob.gaal
We want to use an 1131 AP with IOS version 12.4-3g as workgroup bridge in a Cisco unified wireless infrastructure. We prefer to use PEAP for authentication and AES for encryption (WPA2). If this is not possible EAP-Fast would be an acceptable alternative for authentication. Can someone tell me if this is possible and if so explain me how I need to configure the Access Point?
Thanks in advance.
Greetz,
Rob.
sgossen
Level 4
Level 4
The workgroup bridge must be configured as a client. This is off the top of my head, but should get you pointed in the right direction:
dot11 ssid my_wifi
authent open
authent network-eap 192.168.1.10
authent client usern MYAUTHUSERNAMEHERE password 0 MYPASSWORDHERE
infra
int D0
encryp key 1 size 12 0 MY26DIGITWEPKEYHERE transmit-key
encryption mode ciphers aes-ccm tkip wep128
ssid my_wifi
station-role workgroup-bridge
I believe the WEP key is still required
Later,
Go0se
rob.gaal
In the configuration guide of version 4.1 I see the following:
These features are supported for use with a WGB:
? Guest N+1 redundancy
? Local EAP
? These features are not supported for use with a WGB:
? Cisco Centralized Key Management (CCKM)
? Hybrid REAP
? Idle timeout
? Web authentication
IS PEAP for authentication and AES for encryption supported in the unified infrastructure?
Greetz, Rob
Rob,
Unified Wireless does support PEAP combined with AES encryption.
If You however have to connect a WorkGroupBridge please keep in mind that LEAP, EAP-FAST and EAP-TLS are the only EAP authentication types supported.
You may have to upgrade to IOS 12.4(3g)JA
/Anders
