Workgroup bridge losing connection to AP & other issues
carl_townshend
Hi all
I am having issues where, if I try to connect to a device plugged into my ap, via the workgroup bridge connection, I cannot ping it, however If I jump on the access point and run a ping to the device plugged into it, it is ok, then this brings to life my ping from the lan.
I have also seen some funny things on the log, see below
Sep 10 00:59:37.610: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associa
ted To AP Production_AP1 0016.9d44.8640 [None]
Sep 10 00:59:37.613: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
Sep 10 01:00:34.877: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio0, parent lost: R
eceived deauthenticate (1) failure
Sep 10 01:00:34.877: %DOT11-4-MAXRETRIES: Packet to client 0016.9d44.8640 reache
d max retries, removing the client
Sep 10 01:00:34.882: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to dow
n
Sep 10 01:00:35.050: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio0, Associa
Sep 10 01:00:35.053: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
Any ideas ?
thanks
Carl
0 Replies 0
