WPA and Session Timeout
If i use PEAP or LEAP with WPA do i need the session timeout value 27 in the acs? i know that i can configure that also on the ap but do i still need this timeout with wpa?
mchin345
Level 11
Level 11
Radius, Session-Timeout (027) parameter is used to timeout a PEAP dynamic WEP key. I guess this is an additional security feature, not sure why you would want to disable this.
i knwo that, my question was do i need the attribute 27 when i use PEAP with WPA and not only WEP!
bernhard
raphaelrobertson
Community Member
Since new keys are generated for each frame in WPA, my guess would be no, not needed.
