WPA and WEP on the Same AP
drgebhardt
I'm sure this has been covered in the past, but I've not been able to find the discussion.
I'm looking for a configuration example that supports WEP on one SSID, and WPA-PSK on a second SSID, where each SSID is on a seperate VLAN.
ebreniz
Level 6
Level 6
Here is the link to set up WPA:
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801c40b6.shtml
To set up WEP and WPA at the same time, you must run WEP as optional. You will need to set the transmit key in slot two of the wireless client to match the AP. Please rate the post
