WPA without autentication
konstantin.mueller
Community Member
I configured an AP1130 with WPA and Passkey.
A Symbol WirelessClient can connect to the AP.
Now I like to connect a PC with PCM352 and ACU6.5.
But the configuration only accept user autentification.
And winXP only support WEB128.
Can anyone help.
wong34539
Level 11
Level 11
You can use LEAP authentication to connect the PC to the AP. The ACU will support LEAP authentication. All you have to do is configure a profile for the wireless client adapter which will use LEAP authentication. For information on configuring profiles on the client adapter and configuring LEAP authentication read http://www.cisco.com/en/US/products/hw/wireless/ps4555/module_installation_and_configuration_guides_chapter09186a0080506565.html
rpaulmorris
Community Member
What version of XP are you using? SP2 should nativily support WPA encryption but you must let microsoft" Manage" your wireless networks.
