WPA without autentication
konstantin.mueller
Community Member
I configured an AP1130 with WPA and Passkey.
A Symbol WirelessClient can connect to the AP.
Now I like to connect a PC with PCM352 and ACU6.5.
But the configuration only accept user autentification.
And winXP only support WEB128.
Thanks for help.
andrew.brazier
Level 8
Level 8
The PCM352 and ACU6.5 will only support WPA when you also configure another form of authentication such as RADIUS. Look at the options in the ACU under Security. You might find that if you're using WinXP SP2 you can allow Windows to control the card instead of using the ACU and if so then WPA Passphrase will work.
