WPA2 PSK per AP-Group
JPavonM
I'm almost sure it can't be done but, is it possible to manage different PSK in an AP-group basis?
Other technologies such as Meraki have resolved this with the use of templates, where WLAN security PSK is singular in each venue. Has CUWN some similar feature?
Regards.
M. Wisely
Level 4
Level 4
You'd have to create one WLAN for each AP group to be able to achieve this. The PSK is only configured in the WLAN settings, not in the AP group.
Hope that helps
M. Wisely
Level 4
Level 4
Hope that helps
Scott Fella
You are not able to create multiple SSID's with the same layer 2 encryption on a 2504.  On a 5508 and other platforms, you can do this by creating one on WLAN ID 1-16 and another on WLAN ID 17 and higher.  The only thing is that the WLAN profile name must be unique. I think you can create more than two if you preform it this way.  As far as mobility goes, why not keep them the same, so when users travel to a different site, they don't' have to figure out the psk?
-Scott
-Scott
