Wrong Performance with AP 1262N
Nelsonmejia09
Level 2
Level 2
I have many 1262N and 1031AG APs. when the client is connected to the AP 1262N the performance is slower than it is connected to AP 1031AG (with more clients) in 2.4GHz. any idea why this behavior.
Scott Fella
Is the 1262 negotiated with the switchport correctly?
-Scott
Yes all port settings  are ok.
Provide the output to the following commands:
1.  Switch:  sh interface ;
2.  WAP:  sh interface G0
Since you have a 1262:
1.  How many external antennas are you using?
2.  Did you connect the correct antennas to the correct radio sockets?
