64 Bit SMU files?
I am not able to find downloads for the 64 bit rpm SMU files, the SMU download section only contains the tar files which include txt and pie files, but no rpm. Where is it?
5 Replies 5
ADP_89
Hello Florian,
For which platform are you searching those files? I remeber that for the new 9901 the tar collecting all the x64 rpm was not available on the download section.
Cheers,
ADP
It is not available for any A9K platform as far as I saw, do you know a platform where the rpms are available?
That depends on which release you are talking about, for example 6.3.3 and 6.4.2 don't have any 64-bit SMUs yet.
6.3.2 does have some, they are distinguished from 32-bit by the x64 in their name.
https://software.cisco.com/download/home/282423206/type/280867577/release/6.3.2
Sam
OK my fault then, I was expecting that for 6.4.2 there are already 64bit SMUs as there are a number of 32 bit SMUs already available.
BR,
Florian
for 642  64 bit, there are no SMU's yet
and 32 bit there are few
