A99-RSP-SE and Linecard Bandwidth
NullRoute
If you have an ASR 9910, with two A99-RSP-SEs, how many Fabric Cards do you have? I believe with out adding additional Fabric Cards each RSP has one if that's correct, which would be two Fabric Cards total per 9910?
Trying to figure out how much bandwidth is available from a LC to the Switch Fabric per port. I've looked at some Cisco Live PPTs but not 100% on understanding that part of it.
So is the A99-RSP-SE considered to be a 3rd Generation RSP (Tomahawk)? Trying to see what the difference is between RSP880 and A99-RSP
