ASR 9000 PTP configuration
Stephen Craven
Level 4
Level 4
The RSP-440 has a dedicated 10/100 Ethernet port for PTP. I can find reference to its interface name on page 43 of this document and the port configuration on page 276 of this document.
Both these documents refer to this port as interface PTP0/RSP0/CPU0/0. However I cannot find this interface on the router.
Is there an example specifically for configuring this dedicated PTP interface?
Thank you,
Stephen
xthuijs
hi stephen,
on RSP440 today the interface is not yet supported until you use CSCur72182, fixed in 532.
(not yet visible on bugtoolkit).
xander
xthuijs
hi stephen,
xander
