ASR 9000v sat fails to come up CRS 5.1.3
Aaziz AMHAOUCH
Hi all,
We have a problem in ASR 9000v Satellitte with CRS 5.1.3, it doesn't come UP :
RP/0/RP0/CPU0:CRS#sh nv satellite status
Tue Mar  3 11:54:14.305 UTC
Satellite 200
  Status: Discovery Stalled; Conflict: no Identification received yet
  Type: asr9000v
  IPv4 address: 10.0.0.2 (VRF: NV-MGMT-VRF)
  Configured satellite fabric links:
    TenGigE0/0/0/10
      Remote ports: GigabitEthernet0/0/0-43
RP/0/RP0/CPU0:CRS#
The configuration is as follow:
vrf NV-MGMT-VRF
 address-family ipv4 unicast
interface Loopback1000
 vrf NV-MGMT-VRF
 ipv4 address 10.0.0.1 255.255.255.0
interface TenGi0/0/0/10
 vrf NV-MGMT-VRF
 ipv4 point-to-point
 ipv4 unnumbered Loopback1000
 nv
 satellite-fabric-link satellite 200
 remote-ports GigabitEthernet 0/0/0-43
nv satellite 200
 ipv4 address 10.0.0.2 / 24
 type asr900v
Thanks for your help !
BR
If you need this implemented immediately then you will need the CRS-3 LC.
If you can wait a few months for 5.3.1 then you can use the CRS-X LCs and upgrade the router.
Sam
8 Replies 8
smilstea
The type under nv satellite 200 is incorrect.
'debug nv sat internal dpm all sat 200 detail' will tell us if the software is trying to generate the discovery probes, and the interface counters will tell us if the discovery packets are going out towards the satellite or if the satellite is responding. Discovery messages are sent every second.
HTH,
Sam
Hi Sam,
the config under nv is:
nv
 satellite 200
  type asr9000v
show interfaces:
TenGigE0/0/0/10 is up, line protocol is down
  Interface state transitions: 147
  Hardware is TenGigE, address is 7426.ac47.0533 (bia 7426.ac47.0533)
  Description: Link_toward_nV_Satellite
  Internet address is 10.0.0.1/24
  MTU 1514 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation ARPA,
  Full-duplex, 10000Mb/s, LR, link type is force-up
  output flow control is off, input flow control is off
  loopback not set,
  ARP type ARPA, ARP timeout 04:00:00
  Last input never, output 18:14:06
     0 packets input, 0 bytes, 0 total input drops
     0 drops for unrecognized upper-level protocol
     Received 0 broadcast packets, 0 multicast packets
              0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     2 packets output, 120 bytes, 0 total output drops
     Output 2 broadcast packets, 0 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     147 carrier transitions
RP/0/RP0/CPU0:CRS#
The result of debugging is :
RP/0/RP0/CPU0:CRS#LC/0/0/CPU0:Mar  4 05:49:28.252 : icpe_satfabmgr[193]: [I:dpm-io:0308] Attaching max of 1 interfaces
LC/0/0/CPU0:Mar  4 05:49:28.252 : icpe_satfabmgr[193]: [B:dpm-io:0348] Failed to SPIO attach/detach 1 interfaces: 'Subsystem(3795)' detected the 'warning' condition 'Code(4)'
BR,
Please open a TAC case for troubleshooting, the discovery probes are not being generated / sent out.
Sam
Hi Sam,
Many thanks for your help Sam, It's a CRS-X and you told us tha nvSat is not supported on CRS-X hardware. Is it a compatibility problem with PLIM 40x10G so we can use PLIM 14x10 G or it's not supported on CRS-X chassis ?
BR,
Aaziz
Hi Aaziz,
Just responded to your email.
The issue is the MSC/PLIM. CRS-X LCs will support satellite starting in 5.3.1.
A 14x10GE CRS-3 card will support satellite.
Sam
Hi Sam,
I tested the nv Satellite in CRS-X ver 5.1.3 using a 14x10GE  and it works :
RP/0/RP0/CPU0:CRS#admin sh platform
Wed Mar 11 08:55:35.705 UTC
Node          Type              PLIM               State           Config State
0/0/CPU0      FP-X              40-10GbE           IOS XR RUN      PWR,NSHUT,MON
0/1/CPU0      FP-140G           14-10GbE           IOS XR RUN      PWR,NSHUT,MON
0/RP0/CPU0    RP(Active)        N/A                IOS XR RUN      PWR,NSHUT,MON
0/RP1/CPU0    RP(Standby)       N/A                IOS XR RUN      PWR,NSHUT,MON
0/SM0/SP      FC-400G/S(H)(SP)  N/A                IOS XR RUN      PWR,NSHUT,MON
0/SM1/SP      FC-400G/S(H)(SP)  N/A                IOS XR RUN      PWR,NSHUT,MON
0/SM2/SP      FC-400G/S(H)(SP)  N/A                IOS XR RUN      PWR,NSHUT,MON
0/SM3/SP      FC-400G/S(H)(SP)  N/A                IOS XR RUN      PWR,NSHUT,MON
RP/0/RP0/CPU0:CRS#sh nv satellite status satellite 200
Wed Mar 11 08:56:44.244 UTC
Satellite 200
  Status: Connected (Stable)
  Type: asr9000v
  MAC address: <....>
  Serial Number: <...>
  Remote version: Compatible (not latest version)
    ROMMON: 127.0 (Latest)
    FPGA: 1.13 (Latest)
    IOS: 323.1 (Available: 338.1)
    TenGigE0/1/0/0
      Status: Satellite Ready
RP/0/RP0/CPU0:CRS#
What is your recommendation about this ?
Many Thanks,
BR,
Aaziz
Sam
ok Sam,
Thank you very much for your help :)
BR,
Aaziz
