ASR 9001 BNG dhcp and loopback problems
asagrat777
Hello everyone.
I am trying to configure bng on ASR 9001 (5.1.1) for IPoE using available configuration guides. The most confusing part for me is ip address on access interface. Generally there are three components encompassing/referring client's address space using ipv4 unnumbered lo or specific address: dynamic template, access interface and giaddr in dhcp proxy configuration. So if specific address block is allocated to a client and added to a dhcp server (for example 192.168.1.0/24), then giaddr will be one of the address in this block (192.168.1.1), dynamic template will have address from the same block (192.168.1.1), what ip will be applied to access interface? According to a guide for IPoE:
"The IP unnumbered interface for session (local) address assignment is a mandatory feature configured under an IP dynamic template, and provides basic settings for proper IP session establishment.  The unnumbered interface IP address will become the default gateway for the IP subscriber associated with the session. This address is also used as the "giaddr" in the dhcp proxy configuration to instruct the DHCP server to select an address in which this ipv4 add is routable in"
So I'm using same ip (192.168.1.1) from client block. Here is my configuration:
radius source-interface Loopback4000 vrf MANAGEMENT
radius-server vsa attribute ignore unknown
radius-server host 172.16.1.1 auth-port 1812 acct-port 1813
 key 7 XXXXXXXXXXXXXXXXXXXXX
 timeout 5
 retransmit 1
aaa group server radius BNG_RAD
 server 172.16.1.1 auth-port 1812 acct-port 1813
 vrf MANAGEMENT
aaa attribute format MY_AUTH
 mac-address
aaa attribute format NAS_PORT_FORMAT
 circuit-id plus remote-id separator .
aaa radius attribute nas-port format e SSAAPPPPQQQQQQQQQQVVVVVVVVVVUUUU type 32
aaa radius attribute nas-port-id format NAS_PORT_FORMAT
aaa accounting subscriber default group BNG_RAD
aaa authorization subscriber default group BNG_RAD
aaa authentication subscriber default group BNG_RAD
dhcp ipv4
 vrf CLIENT proxy profile CLIENT
 profile CLIENT proxy
  helper-address vrf CLIENT 192.100.100.1 giaddr 192.168.1.1
  relay information option
  relay information policy keep
  relay information option allow-untrusted
 interface GigabitEthernet0/0/0/0.50 proxy profile CLIENT
dynamic-template
 type ipsubscriber IPSUB_TPL
  vrf CLIENT
  ipv4 unnumbered Loopback346
  ipv4 access-group PERM_ALL ingress
  ipv4 access-group PERM_ALL egress
ipv4 access-list PERM_ALL
 10 permit ipv4 any any
class-map type control subscriber match-any DHCP
 match protocol dhcpv4
 end-class-map
policy-map type control subscriber IP_PM
 event session-start match-first
  class type control subscriber DHCP do-until-failure
   5 activate dynamic-template IPSUB_TPL
 end-policy-map
 description ### CLIENT SUBSCRIBERS ###
 ipv4 point-to-point
 service-policy type control subscriber IP_PM
 encapsulation dot1q 50
 ipsubscriber ipv4 l2-connected
  initiator dhcp
interface Loopback345
 description ### BASE UNUSED IP FOR ACCESS INTERFACE ###
 ipv4 address 11.11.11.11 255.255.255.255
interface Loopback346
 description ### SUBNET FOR SUBSCRIBERS ###
 vrf CLIENT
 ipv4 address 192.168.1.1 255.255.255.0
 description ### Loopback for MANAGEMENT ###
 vrf MANAGEMENT
 ipv4 address 172.16.1.100 255.255.255.255
After commiting, session is not created and in debugs there are errors:
LC/0/0/CPU0:Mar 28 15:19:59.676 : dhcpd[154]: DHCPD ERROR: TP3301: Failed to get interface handle for  Loopback346
LC/0/0/CPU0:Mar 28 15:19:59.676 : dhcpd[154]: DHCPD ERROR: TP2526: Access interface Unknown with NULL primary address
LC/0/0/CPU0:Mar 28 15:19:59.676 : dhcpd[154]: DHCPD PROXY ERROR: TP1887: Giaddr policy error, chaddr d485.64eb.045c
LC/0/0/CPU0:Mar 28 15:19:59.676 : dhcpd[154]: DHCPD PROXY ERROR: TP1513: Process DISCOVER failed for chaddr d485.64eb.045c
LC/0/0/CPU0:Mar 28 15:19:59.676 : dhcpd[154]: DHCPD PROXY ERROR: TP1665: Proxy process client request packet failed for chaddr d485.64eb.045c
LC/0/0/CPU0:Mar 28 15:19:59.676 : dhcpd[154]: DHCPD ERROR: TP1675: Base process event returned failure for chaddr d485.64eb.045c: sub_label 0x4000038 (67108920)
If unnumbered loopback inside access interface is changed to loopback 345 containing  some unused ip address (11.11.11.11), then session is created, client received ip and everything is working. In debugs:
LC/0/0/CPU0:Mar 28 15:46:23.707 : dhcpd[154]: DHCPD ERROR: TP3301: Failed to get interface handle for  Loopback346
LC/0/0/CPU0:Mar 28 15:46:23.866 : dhcpd[154]: DHCPD EVENT: TP750: RSI event for interface received. Intf = GigabitEthernet0/0/0/0.50.ip10, VRF CLIENT, Event 0
LC/0/0/CPU0:Mar 28 15:46:37.599 : dhcpd[154]: DHCPD ERROR: TP2468: rib route delete failed, null ifhandle or IPv4 address
LC/0/0/CPU0:Mar 28 15:46:37.702 : dhcpd[154]: DHCPD ERROR: TP2678: DPM session disconnect for chaddr d485.64eb.045c, sub_label 0x0 (0) returned failure: 'Subsystem(4791)' detected the 'warning' condition 'Code(3)'
LC/0/0/CPU0:Mar 28 15:46:38.036 : dhcpd[154]: DHCPD EVENT: TP750: RSI event for interface received. Intf = GigabitEthernet0/0/0/0.50.ip10, VRF CLIENT, Event 1
LC/0/0/CPU0:Mar 28 15:46:40.364 : dhcpd[154]: DHCPD ERROR: TP3301: Failed to get interface handle for  Loopback346
LC/0/0/CPU0:Mar 28 15:46:40.498 : dhcpd[154]: DHCPD EVENT: TP750: RSI event for interface received. Intf = GigabitEthernet0/0/0/0.50.ip11, VRF CLIENT, Event 0
After session creation periodically the following warning is observed:
 LC/0/0/CPU0:Mar 28 10:46:45.043 : dhcpd[154]: %IP-DHCPD-4-INVALID_DEFAULT_GATEWAY : Invalid! default gateway, Client(d485.64eb.045c) Release/Renew send may fail
It must be noted that unused ip inside access interface is used by client as DHCP server's IP which forces client to send dhcp messages to a wrong address.
Any help will be appreciated.
15 Replies 15
Do you possibly have DHCP inform messages going around?
if that is the case, which is smells like, since you dont see any affected problems here and also it is said that the ip addr and gateway are fine then I can explain it as follows.
There is a check in sw that does this:
In the code we have this condition:
if ((server_id & subnet_mask) != (pak->yiaddr & subnet_mask)) {
so basially if the address of the user and subnet doesnt fit in the gateway and subnet, we spit this message, BUT the issue is with DHCP INFORM. When we sent ACK on INFORM yiaddr will be 0.0.0.0 as per RFC. So this check will fail and print that message.
need to fix that in sw.
so fi you have inform, you can ignore this.
xander
