ASR 9K IOS XR - Question regarding Link Bundling Load Balancing
3alee
Hello
<Testbed>
IOSXR  4.1.0.
Refer to attached diagram,  I ping form src:200.200.200.200 (and 172.30.1.2) to  dst:100.100.100.100(and 192.168.1.2)(different source/destination  combination).
Check  load balancing per source base, I expect
Packet  go through as
Int  g0/0/0/15   >>50%
Int  g0/0/0/16   >>50%
However, the actual result is:
Int  g0/0/0/15   >>100%
Int  g0/0/0/16   >>0%
ASR configuration as  attached.
Is there any configuration missing?
Thanks!
David Powers
Since this is ipv4 unicast to ipv4 unicast the following hashing applies:
Since icmp has no layer 4 protocol then it will hash to one of the bundle members based on IP SA, IP DA and router id.
IPv4 Unicast
No Layer 4 protocol  -  Based on IP SA, DA and Router ID
Unknown Layer 4 protocol  -  Based on IP SA, DA and Router ID
TCP  -  Based on IP SA, DA, TCP Src Port, TCP Dst Port and Router ID
UDP  -  Based on IP SA, DA, UDP Src Port, UDP Dst Port and Router ID
SCTP (Stream Control Transmission Protocol ) -  Based on IP SA, DA, SCTP Src Port, SCTP Dst Port and Router ID
You can determine which bundle member the packets will hash to using the bundle-hash command.
router#bundle-hash bundle-ether1
Thu Jul 21 16:44:53.477 UTC
Calculate Bundle-Hash for L2 or L3 or sub-int based: 2/3/4 [3]: 3
Enter traffic type (1.IPv4-inbound, 2.MPLS-inbound, 3:IPv6-inbound): [1]: 1
Single SA/DA pair or range: S/R [S]:
Enter source IPv4 address [255.255.255.255]: 192.168.1.20
Enter destination IPv4 address [255.255.255.255]: 192.168.1.26
Compute destination address set for all members? [y/n]: y
Enter subnet prefix for destination address set: [32]:
Enter bundle IPv4 address [255.255.255.255]:
Enter L4 protocol ID. (Enter 0 to skip L4 data) [0]:
Invalid protocol. L4 data skipped.
Link hashed [hash_val:0] to is TenGigE0/0/0/6 member id 0 ifh 0x400
If  this had been two equal cost L3 paths instead of a bundle-ether then  you would use show cef exact-route to determine  which link will be selected.
In Summary:
Each flow will hash to one or the other links based on the  hashing algorithm. It's deterministic based on the details of the flow.  In your case both flows just happened to hash to the same bundle member  so all the traffic ended up on one bundle member. If you had used a SA  DA pair that hashes to the other link then you would have seen the 50/50  load balancing that you were expecting. If you had many different flows over this bundle then you would see a more even distribution of traffic even though it will not be equal in real world situations outside of the lab.
Thanks a lot!
Hi everyone,
Can anyone help to solve the issue regarding load balancing between ASR9k and Cat6509.
We have done Load balance regarding ip
RP/0/RSP0/CPU0:ASR_9010_1#show interfaces bundle-ether 2
Fri Dec  2 16:28:57.664 MSD
Bundle-Ether2 is up, line protocol is up
  Interface state transitions: 1
  Hardware is Aggregated Ethernet interface(s), address is 4055.392c.14e2
  Description: to_Cisco6509
  Internet address is Unknown
  MTU 1514 bytes, BW 20000000 Kbit (Max: 20000000 Kbit)
     reliability 255/255, txload 60/255, rxload 13/255
  Encapsulation ARPA,  loopback not set,
  ARP type ARPA, ARP timeout 04:00:00
    No. of members in this bundle: 3
        TenGigE0/1/0/4       Full-duplex      10000Mb/s    Active
        TenGigE0/2/0/4       Full-duplex      10000Mb/s    Active
        TenGigE0/3/0/1       Full-duplex      10000Mb/s    Configured
  Last input 00:00:00, output 00:00:00
  Last clearing of "show interface" counters 01:16:49
  5 minute input rate 1064973000 bits/sec, 488001 packets/sec
  5 minute output rate 4730570000 bits/sec, 620943 packets/sec
     2240244835 packets input, 620460311627 bytes, 308 total input drops
     393 drops for unrecognized upper-level protocol
     Received 140 broadcast packets, 72703 multicast packets
              0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     2846541625 packets output, 2715246843512 bytes, 0 total output drops
     Output 36 broadcast packets, 2909 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     0 carrier transitions
Port-channel8 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0026.99e5.ce53 (bia 0026.99e5.ce53)
  Description: To_ASR9K_1
  MTU 1500 bytes, BW 20000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 13/255, rxload 60/255
  Keepalive set (10 sec)
  Full-duplex, 10Gb/s, media type is unknown
  input flow-control is off, output flow-control is off
  Members in this channel: Te7/2 Te7/7
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 01:17:14
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 4727599000 bits/sec, 620528 packets/sec
  5 minute output rate 1065604000 bits/sec, 487869 packets/sec
     4242596399 packets input, 4054351424974 bytes, 0 no buffer
     Received 4312 broadcasts (4261 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     3333670777 packets output, 912621405566 bytes, 0 underruns
But we may see traffic restriction 10 Gb/s.
What can be cause of the problem?
Is there soft restriction exist?
ASR9k 4.0.3
Thanks.
