ASR9000 Queues
dfranjoso
Hello IOSXR Experts,
When doing the following command
show qos summary queue interface GigabitEthernet0/4/0/28.300 output
i get different QueueIDs from the following command
show policy-map interface GigabitEthernet0/4/0/28.300 output
Which numbering is the correct one ?
Another issue is that there is no queue ID for the parent policy-map (it says N/A on the show qos summary queue command).
policy-map SCH_OUT_parent_L3_QOS3_100M
class class-default
  service-policy SCH_OUT_child_L3_QOS3_100M
  shape average 100 mbps
end-policy-map
The parent policy-mao shaper does use a queue, so what's the number of that ?
Thanks!
Alexei Kiritchenko
Hi David,
May you put full qos configuration and complete output from the qos commands?
Which IOX XR version do you have?
/A
