ASR9901 maximum IP route entries
This might be a trivial question for you guys, but I am not able to find the answer.
What is the limit of IP routes an ASR9901 can handle? Could you please point me to a document/reference about it?
Datasheet does not mention it.
Ariel
smilstea
So the RIB for eXR supports 10M v4 and 5m v6 1D scale.
This is significantly higher than cXR due to it being 64-bit.
Sam
Could you share some literature where we can read this, even for other models?
We don't typically publish scale info. Other models for cXR or eXR will share the same scale, the scale has not changed based on generations of LC, its purely related to 32-bit and 64-bit memory allocation limits for the router and components.
Sam
What information should we used to evaluate scalation with respect routing tables when this information is not publicly available? The original question is regarding the ASR9901, a compact model which has no LC.
