ASR9k RADIUS PoD and COA
joshuacmoore
Is there a generic configuration example that I can use for reference on how to setup my BNG to receive RADIUS PoD and/or COA requests? Also, can someone tell me what attributes or information is required to be sent from the RADIUS server for this?
5 Replies 5
xthuijs
hi joshua,
you onlt need to configure the aaa dynamic author piece and list the clients that you want the bng to receive COA requests from.
then when you send a COA request with the POD type code and when the attributes match a (single) session, eg via framed ip, username or accounting session ID then you can disconnect the subscrober.
to generate POD or COA requests you can use the tool from here
xander
Is there a debug I can run on the ASR BNG to show me just the incoming COA requests?
my lab is down this week due to some power work, so I can't verify, but it should be debug aaa coa or debug radius coa or something similar to that Josh.
xander
"deb aaa coa" is in ASR1k IOS -XE. I couldn't find any similar debug command in XR.
right!
use debug radius dynamic-author for XR.
xander
