02-14-2020 02:14 AM
Does anybody know what this logs came from and what they mean ?
Konrad
RP/0/RSP0/CPU0:Feb 13 17:00:23.175 bgp[3455]: ^H8o^TY^Q^W^Vql"^U^_<q^Q^T(null)(null)Color network (null) (path ID: ) received from 203.3.3.40
RP/0/RSP0/CPU0:Feb 13 17:00:23.175 bgp[3455]: ^H8o^TY^Q^W^Vql"^U^_<q^Q^T(null)(null)Prefix (null) received with color attribute from 203.3.3.40 flags 0xc00000 found color 50331648
RP/0/RSP1/CPU0:Feb 13 17:00:23.175 bgp[3455]: 8^R+^UMv^\^]1}#,^_<a ^T(null)(null)Color network (null) (path ID: ) received from 203.3.3.40
RP/0/RSP1/CPU0:Feb 13 17:00:23.175 bgp[3455]: 8^R+^UMv^\^]1}#,^_<a ^T(null)(null)Prefix (null) received with color attribute from 203.3.3.40 flags 0xc00000 found color 50331648
RP/0/RSP0/CPU0:Feb 13 17:00:53.494 bgp[3455]: @(o^T^T'y^T^P^Wq^T^\<q^Q^T(null)(null)Color network (null) (path ID: ) received from 203.3.3.39
RP/0/RSP0/CPU0:Feb 13 17:00:53.494 bgp[3455]: @(o^T^T'y^T^P^Wq^T^\<q^Q^T(null)(null)Prefix (null) received with color attribute from 203.3.3.39 flags 0xc00000 found color 50331648
RP/0/RSP1/CPU0:Feb 13 17:00:53.493 bgp[3455]: ^PW4^U }6^UDa5^U^\<a ^T(null)(null)Color network (null) (path ID: ) received from 203.3.3.39
RP/0/RSP1/CPU0:Feb 13 17:00:53.493 bgp[3455]: ^PW4^U }6^UDa5^U^\<a ^T(null)(null)Prefix (null) received with color attribute from 203.3.3.39 flags 0xc00000 found color 50331648
RP/0/RSP0/CPU0:Feb 13 17:00:53.595 bgp[3455]: @(o^T^T'y^T^P^Wq^T^\<q^Q^T(null)(null)Color network (null) (path ID: ) received from 203.3.3.40
RP/0/RSP0/CPU0:Feb 13 17:00:53.595 bgp[3455]: @(o^T^T'y^T^P^Wq^T^\<q^Q^T(null)(null)Prefix (null) received with color attribute from 203.3.3.40 flags 0xc00000 found color 50331648
RP/0/RSP1/CPU0:Feb 13 17:00:53.595 bgp[3455]: ^PW4^U }6^UDa5^U^\<a ^T(null)(null)Color network (null) (path ID: ) received from 203.3.3.40
RP/0/RSP1/CPU0:Feb 13 17:00:53.595 bgp[3455]: ^PW4^U }6^UDa5^U^\<a ^T(null)(null)Prefix (null) received with color attribute from 203.3.3.40 flags 0xc00000 found color 50331648
RP/0/RSP0/CPU0:Feb 13 17:01:09.632 bgp[3455]: ^\9o^TX^Q^W^V@(o^T^Z<q^Q^T(null)(null)Color network (null) (path ID: ) received from 203.3.3.39
RP/0/RSP0/CPU0:Feb 13 17:01:09.632 bgp[3455]: ^\9o^TX^Q^W^V@(o^T^Z<q^Q^T(null)(null)Prefix (null) received with color attribute from 203.3.3.39 flags 0xc00000 found color 50331648
RP/0/RSP1/CPU0:Feb 13 17:01:09.631 bgp[3455]: L^S+^ULv^\^]^PW4^U^Z<a ^T(null)(null)Color network (null) (path ID: ) received from 203.3.3.39
RP/0/RSP0/CPU0:Feb 13 17:01:09.633 bgp[3455]: ^\9o^TX^Q^W^V@(o^T^Z<q^Q^T(null)(null)Color network (null) (path ID: ) received from 203.3.3.40
02-15-2020 01:34 PM
This issue was just reported by a couple of other customers a few days ago, from a codewalk we can see that the issue is related to TE BGP ODN looking for color attribute in BGP external communities.
I would recommend opening a TAC case with show tech routing bgp, dumpcore running bgp, show logging, show install active summary.
Sam
02-19-2020 12:18 PM
Follow bug has been filed:
CSCvj01353
<B>Symptom:</B>
Excessive Syslogs printed when extended community color attribute received.
<B>Conditions:</B>
Affected releases:
IOS-XR 6.3.1
IOS-XR 6.3.2
IOS-XR 6.3.3
IOS-XR 6.3.15
IOS-XR 6.4.0
IOS-XR 6.4.1
IOS-XR 6.4.2
Device configured with BGP and receiving extended communities.
<B>Workaround:</B>
Use the attribute filter:
router bgp 1
attribute-filter group example
attribute EXTENDED-COMMUNITIES discard
neighbor 10.10.10.1
update in filtering
<B>Further Problem Description:</B>
Sam
