BNG on XRV 5.2 ?
michalzubryk
I have a question about XRv, it is necessary to specifically activate the service BNG?
I installed
   Boot Image: /disk0/xrvr-os-mbi-5.2.0/mbixrvr-rp.vm
     Active Packages:
       disk0: xrvr-full-x-5.2.
The image iosxrv-demo-5.2.0.vmdk
But there is no active command to run the BNG,
I mean here the command "ipsubscriber"
It is not active or the Physical interface or the BUNDLE
Thanks in advance for your help.
MichalZ
Alexei Kiritchenko
Hello Michal,
BNG is not supported yet on XRv.
Regadrs,
/A
Hi Alexei,
Has there been any movement since?
Chris
YES! we called it vBNG.
starting xr 631 (eft available), you can use BNG as a vmachine for subscriber termination with pretty impressive scale!
32k subs, 40G bw and that on a single hexcore socket!
xander
