Friends,
I am purchasing an ASR1002 cisco with two ports of 10Gbps + license for 24,000 pppoe sessions.
It will be used as Bras but alerted me as to its memory so when there is any problem like mass drop of pppoe sessions it can crash and stop responding.
I would like to hear from you. It has 4GB of memory and no possibility to upgrade. I found it odd that it does not support since it has license of 24,000 sessions for this router, it is to support otherwise Cisco would not sell this license to him.
What do you say?
I will put two ASR1001 with 10.000 pppoe sessions each passing traffic of 5Gbps.
Does this machine work perfectly? Would memory be a problem? Does the processor support?
It will run:
1) server pppoe for radius with 10,000 pppoe sessions;
2) mpls
3) ospf v4 and v6
Router#show platform
Chassis type: ASR1002
Slot Type State Insert time (ago)
0 ASR1002-SIP10 ok 00:10:42
0/0 4XGE-BUILT-IN ok 00:06:45
0/1 SPA-1X10GE-L-V2 ok 00:06:45
0/2 SPA-1X10GE-L-V2 ok 00:06:45
R0 ASR1002-RP1 ok, active 00:10:42
F0 ASR1000-ESP10 ok, active 00:10:42
P0 ASR1002-PWR-AC ok 00:08:21
P1 ASR1002-PWR-AC ps, fail 00:08:20
Slot CPLD Version Firmware Version
0 07120202 12.2(33r)XNC
R0 08011017 12.2(33r)XNC
F0 07091401 16.2(1r)
Router#
Router#show platform re
Router#show platform resources
**State Acronym: H - Healthy, W - Warning, C - Critical
Resource Usage Max Warning Critical State
RP0 (ok, active) H
Control Processor 13.40% 100% 90% 95% H
DRAM 1837MB(48%) 3783MB 90% 95% H
ESP0(ok, active) H
Control Processor 22.13% 100% 90% 95% H
DRAM 666MB(33%) 1962MB 90% 95% H
QFP H
TCAM 8cells(0%) 131072cells 45% 55% H
DRAM 85007KB(16%) 524288KB 80% 90% H
IRAM 10453KB(7%) 131072KB 80% 90% H
SIP0 H
Control Processor 6.10% 100% 90% 95% H
DRAM 355MB(77%) 460MB 90% 95% H
