10-24-2014 09:07 AM
Seeking clarification as to if the class-default would utilize available remaining bandwidth based on the remaining bandwidth and queue packet limit config.
I have a 12416 | Cisco IOS XR Software, Version 4.1.2
2XT1 multilink interface as follows:
interface Multilink0/10/0/0/115
service-policy input V4_Ex_20:60:30:10_in
service-policy output V4_Ex_20:60:30:10_out_4M
vrf 13979:283866
ipv4 address 192.168.10.126 255.255.255.252
encapsulation ppp
keepalive disable
The question concerns service-policy output V4_Ex_20:60:30:10_out_4M....
policy-map V4_Ex_20:60:30:10_out_4M
class cos1_class
priority level 1
police rate percent 20 burst 250 ms peak-burst 250 ms
exceed-action drop
class control_class
bandwidth percent 5
queue-limit 320 packets
class cos2_class
bandwidth remaining percent 60
random-detect dscp 24,26 192 packets 320 packets
random-detect dscp 25,27,28,29,30,31 96 packets 160 packets
class cos3_class
bandwidth remaining percent 30
random-detect dscp 16,18 192 packets 320 packets
random-detect dscp 17,19,20,21,22,23 96 packets 160 packets
class class-default
bandwidth remaining percent 10
end-policy-map
Based on this configuration would the class-default not utilize any existing remaining bandwidth as needed versus tail dropping as it is per the output below..? The end user is knowingly not tagging the COS 2 traffic correctly therefore causing much of the traffic to flow to the class-default bucket...although we will get this corrected I was wondering why the packets got dropped regardless of the tagging as I understood the class-default would consume remaining bandwidth. Is the bandwidth remaining and queue limit config lines as configured above putting restrictions on this capability? Any feedback would be greatly appreciated. I have scrubbed lots of documentation but finding it hard to place my finger on something decisive.
Multilink0/10/0/0/115 output: V4_Ex_20:60:30:10_out_4M
Class cos1_class
Classification statistics (packets/bytes) (rate - kbps)
Matched : 14331896/1068064350 31
Transmitted : 14331814/1067962471 31
Total Dropped : 82/101879 0
Policing statistics (packets/bytes) (rate - kbps)
Policed(conform) : 14331814/1067962471 31
Policed(exceed) : 82/101879 0
Policed(violate) : 0/0 0
Policed and dropped : 82/101879
Queueing statistics
Queue ID : 304
High watermark : N/A
Inst-queue-len (packets) : 0
Avg-queue-len (packets) : 0
Taildropped(packets/bytes) : 0/0
Class control_class
Matched : 0/0 0
Transmitted : 0/0 0
Total Dropped : 0/0 0
Queueing statistics
Queue ID : 302
Class cos2_class
Matched : 0/0 0
Transmitted : 0/0 0
Queueing statistics
Queue ID : 300
RED random drops(packets/bytes) : 0/0
RED maxthreshold drops(packets/bytes): 0/0
WRED profile for Label 1
DSCP: 24 26
RED Transmitted (packets/bytes) : N/A
WRED profile for Label 2
DSCP: 25 27 28 29 30 31
Class cos3_class
Matched : 1324919/478941081 2
Transmitted : 1324919/478941081 2
Queueing statistics
Queue ID : 301
DSCP: 16 18
DSCP: 17 19 20 21 22 23
Class class-default
Matched : 54233413/24240606239 546
Transmitted : 54099865/24154788424 546
Total Dropped : 133548/85817815 0
Queueing statistics
Queue ID : 303
Inst-queue-len (packets) : 9
Avg-queue-len (packets) : 1
Taildropped(packets/bytes) : 133548/85817815
10-27-2014 05:43 AM
Looks like you have a SIP700 card, this one is CPP based (as opposed to Typhoon NPU based on the ether LC's).
you need to check the command show qos-hal for that linecard to see what the programming looks like for that queue.
in this config snippet you show, with bandwidth and bw remaining you set the CIR of the queue.
so now you're applying a minimum bw to that queue and hence a weighted ratio.
if you omit that, it will get whatever is left, but it is scheduled in an MDRR methodology.
xander
