CPU reset reason = 8, why ROMmon software display it?
Hi everyone.
Already i'm working whit a A99-12X100GE line card,
During boot up into ROMmon, serial console show as follow
Somebody may help me to know why board restar twice?
Thanks in advance
 Booting Management Processor
skyhammer_init()
NVSRAM device ID 681C8A0
hwlog_init() : INFO : NVSRAM RTC oscillator already disabled.
Power down on card removal (OIR power down) is enabled
PLX PEX configured from SEEPROM revision 0.3
configure NTB
Assign bus number
configure NTB
debug NT0 bar size 400000
skyhammer_morra0_init()
Morra 0 PCIe autonomous register restoration enabled.
skyhammer_sideswipe0_init()
Sideswipe 0 PCIe autonomous register restoration enabled.
skyhammer_morra1_init()
Morra 1 revision 1.2
  loading GPIO tables for rev greater than or equal to 6
DB Revision : 6
PLX PEX configured from SEEPROM revision 0.1
Morra 1 PCIe autonomous register restoration enabled.
skyhammer_sideswipe1_init()
Sideswipe 1 PCIe autonomous register restoration enabled.
Booting Main Processor
Switching to line card CPU console
 [=3h[=3h [=3h[=3h[=3h
ASR9K Init Starting ASR9k initialization ...
Reading both MB and DB cookie
Board Type:0x3d02c3
Non Powerglide & STLRD Stetting i2c block 3
 The base address of i2c_mux4to1 is at d2300800
zl init Skyhammer
Initializing Zl clock to 156MHz
Missing Parameter SERVER_URL
System Bootstrap, Version 9.30 [ASR9K x86 ROMMON],
Copyright (c) 1994-2019 by Cisco Systems, Inc.
Compiled on Tue 07/16/2019 14:52:26.92
BOARD_TYPE             : 0x3d02c3
Rommon                 : 9.30 (Primary)
IPU FPGA(PL)           : 0.16.0 (Primary)
IPU INIT(HW.FPD)       : 1.89.0
IPU FSBL(BOOT.BIN)     : 1.112.0
IPU LINUX(IMAGE.FPD)   : 1.112.0
MORRA MB FPGA          : 1.2.0
SIDESWIPE MB FPGA      : 1.2.0
CBC0                   : Part 1=46.6, Part 2=46.6, Act Part=2
Product Number         : A99-12X100GE
Slot Number            : 0
Got EMT Mode as IOS-XR Boot
Since response is not received for os_type, switch to IOS-XR 32 bit
Got CBC OS type as IOS-XR 32 bit
Unexpected value, Got Boot Mode=65535
Booting IOS-XR (32 bit Classic XR) - Press Ctrl-c to stop
Checking OS type.
CBC OS type detected emt_mode 3 CBC OS type as 2
Set CBC OS type IOS-XR 32 bit, EMT IOS-XR Boot to CBC
[PCIe Link] HOOPER_0 status: (up)0x7011 (dw)0x1011 <OK>
[PCIe Link] HOOPER_1 status: (up)0x7011 (dw)0x1011 <OK>
[PCIe Link] HOOPER_2 status: (up)0x7011 (dw)0x1011 <OK>
[PCIe Link] HOOPER_3 status: (up)0x7011 (dw)0x1011 <OK>
[PCIe Link] NIAN0_0 status: (up)0x2082 (dw)0x1082 <OK>
MAC Init: need programming MAC address
SNP MAC Init: bus 26 port 0
SNP MAC Init: bus 26 port 1
SNP MAC Init: bus 29 port 0
MAC Init SNP: PXE port found
SNP MAC Init: MAC address updated.
SNP MAC Init: bus 29 port 1
ASR9K FPD Starting ASR9k fpd check ...
Connecting all
Located CiscoSec Protocol
Internal EFI ShellUEFI Interactive Shell v2.1
EDK II
UEFI v2.40 (INSYDE Corp., 0x55150021)
Mapping table
      FS0: Alias(s):HD72a0a1:;BLK1:
          PciRoot(0x0)/Pci(0x1F,0x2)/Sata(0x0,0x0,0x0)/HD(1,MBR,0x00000000,0x20,0x68F7E0)
      FS1: Alias(s):HD72a0a2:;BLK2:
          PciRoot(0x0)/Pci(0x1F,0x2)/Sata(0x0,0x0,0x0)/HD(2,MBR,0x00000000,0x68F800,0x65E800)
      FS2: Alias(s):HD72a0a3:;BLK3:
          PciRoot(0x0)/Pci(0x1F,0x2)/Sata(0x0,0x0,0x0)/HD(3,MBR,0x00000000,0xCEE000,0x1CF5000)
     BLK0: Alias(s):
Press ESC in 5 seconds to skip startup.nsh or any other key to continue.Press ESC in 4 seconds to skip startup.nsh or any other key to continue.Press ESC in 3 seconds to skip startup.nsh or any other key to continue.Press ESC in 2 seconds to skip startup.nsh or any other key to continue.Press ESC in 1 seconds to skip startup.nsh or any other key to continue.
Enter efi_start
Enter vx86rmon_efi_start image_handle 0x65244398 system_table 0x684fef18
Entering vx86rmon_init
 intializing Tomahawk LC RomMon
LC will boot from RP1/RSP1.
Board Type:0x3d02c3
Non Powerglide & STLRD Settting i2c block 3
zl init Skyhammer
CPU reset reason = 8 (CPU_RESET_WDOG_POR)
B1:D0:F0: ASPM=0x420000
B1:D0:F1: ASPM=0x420000
B1:D0:F2: ASPM=0x420000
B1:D0:F3: ASPM=0x420000
B1:D0:F4: ASPM=0x420000
B2:D1:F0: ASPM=0xa0420000
B2:D8:F0: ASPM=0xa0430000
B18:D0:F0: ASPM=0x430000
Morra DB access problem, no fabric asic link check
morra1_rev_data=0xffffffff
DRAM Frequency: 2133 MHz
Memory Size: 32768 MB
EDK II
Mapping table
     BLK0: Alias(s):
Mapping table
     BLK0: Alias(s):
EDK II
Mapping table
     BLK0: Alias(s):
Mapping table
      FS0: Alias(s):HD72a0a1:;BLK1:;disk0:
EDK II
Mapping table
     BLK0: Alias(s):
Mapping table
      FS1: Alias(s):HD72a0a2:;BLK2:;disk0a:
EDK II
Mapping table
     BLK0: Alias(s):
Mapping table
      FS2: Alias(s):HD72a0a3:;BLK3:;usb:
Valid Flash Device returned -
Device Type 3
Id 1620512, ExtId 0, Size 8, VendorName Micron DeviceName N25Q128A
The value of autoc is 0xc09c2205
[NIANTIC] PCIE LINK UP
[Niantic] INTEL EOBC LINK UP
rommon 1 >
rommon 1 >
rommon 1 >
mivens
It's a Watchdog timeout causing the linecard to be power cycled as per
https://community.cisco.com/t5/xr-os-and-platforms/asr9k-5-1-3-is-there-somewhere-that-provies-us-a-list-of-reset/m-p/2728638/highlight/true#M5894
What version of IOS-XR are you trying to get the LC to work with and on what hardware (post "show platform" output)?
Is this the first time you have tried to get the A99-12X100GE to work with that hardware/software combination?
Thanks for quick replay.
I'm using IOS-XR 32 bit Classic XR, I start to diagnose these types of products.
Actually I'm doing diagnostic test using a test sequence. During boot test sequence is waiting for catch a rommon promt, however, unit under test reset twice and time-out expired. I just want to know if CPU_RESET_REASON 8 act out a hardware/software issue whit CPU or microcontroller. In that case, is there any document that can help me to understand better this CPU reset reason?
Thanks in advance.
The watchdog timeout is most likely a symptom of the card not booting in a timely fashion, not the root-cause.
The first thing to do is to confirm the software/hardware combination is supported for that card. Hence the previous questions (which I don't believe have been answered) about which XR version is being used and what other hardware is in the router.
