[CRS3][4.2.3] failed configuration for qos under 1-100GE subinterface
Hongju Jung
Hi Everyone
I have some strange resulted as a below
RP/0/RP0/CPU0:CRS-3(config)#interface hu0/5/0/0.1
RP/0/RP0/CPU0:CRS-3(config-subif)#service-policy output PQ_WRR_BB
RP/0/RP0/CPU0:CRS-3(config-subif)#commit
Tue Dec 10 17:04:50.072 KST
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted. Please issue 'show configuration failed' from this session to view the errors
RP/0/RP0/CPU0:CRS-3(config-subif)#show configuration failed
Tue Dec 10 17:04:56.171 KST
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
interface HundredGigE0/5/0/0.1
!!% 'qos_ea' detected the 'fatal' condition 'QoS is not supported on sub-interfaces'
end
Do you have any idea how to deployed above QoS configuration under Hundred subinterface ?
Please let me know it any documentation or advice for me ASAP
thanks.
Hello Hongju,
Normally if you have FP140, QoS on the subinterface itself is not supported...
However what i suggest you do is to match on the VLAN related for this subinterface and configure your policy under the physical interface:
interface hu0/5/0/0
desc vlanA
class-map match-any vlanA
match vlan A
end-class-map
policy-map PQ_WRR_BB
class vlanA
  police rate XXX mbps
   conform-action transmit
   exceed-action drop
Hope this helps.
Michel.
Hello Michel
Thanks for reply our concern but I have some question as a below
1, we will deplying 6 sub-interface with below policy rule
class VOIP_ROUTING
  priority level 1
  police rate percent 100
class EXP
  bandwidth remaining percent 20
  random-detect default
class UDP
  bandwidth remaining percent 10
class class-default
  bandwidth remaining percent 70
end-policy-map
You mea, we will defined each vlan (A) have defined with above rule by each vlan classs, right  ?
thanks
