CSM 2.0 install problem
DAVID YARASHUS
Level 5
Level 5
I'm having trouble installing CSM 2.0 on a Windows 8 computer.  I tried running the normal setup script, and that failed, so I tried running it manually at the command line, and it fails with the same error but a little more debugging information (see below):
C:\Users\testuser\Downloads\IOS-XR\CSM-2.0>java -jar .\installer.jar
Jul 07, 2015 5:54:55 PM com.cisco.hfr.cwi.installer.InstallerApplet install
INFO: CSM Home directory : C:\Users\testuser\csm\csm
Jul 07, 2015 5:54:55 PM com.cisco.hfr.cwi.installer.CWIDescriptor getCWIFile
INFO: file for cwi_if.jar is com.cisco.hfr.cwi.installer.CWIFile@2ae4bd
Jul 07, 2015 5:54:55 PM com.cisco.hfr.cwi.installer.CacheUtilities getCacheFilePath
INFO: Cache file name : C:\Users\testuser\csm\csm\versions\2.0\cwi_if.jar
Jul 07, 2015 5:54:55 PM com.cisco.hfr.cwi.installer.LocalCopyFileRetriever getFiles
INFO: File to be copied is : C:\Users\testuser\csm\csm\versions\2.0\cwi_if.jar
INFO: Caching : C:\Users\testuser\Downloads\IOS-XR\CSM-2.0\cwi_if.jar
INFO: Cache file name : C:\Users\testuser\csm\csm\versions\2.0\csm\1.0\cwi_ne.jar
INFO: File to be copied is : C:\Users\testuser\csm\csm\versions\2.0\csm\1.0\cwi_ne.jar
INFO: Caching : C:\Users\testuser\Downloads\IOS-XR\CSM-2.0\csm\cwi_ne.jar
SEVERE: IOException occurred during installation.
java.io.FileNotFoundException: C:\Users\testuser\Downloads\IOS-XR\CSM-2.0\csm\cwi_ne.jar (The system cannot find the file specified)
        at java.io.FileInputStream.open0(Native Method)
        at java.io.FileInputStream.open(Unknown Source)
        at java.io.FileInputStream.<init>(Unknown Source)
        at com.cisco.hfr.cwi.installer.InstallerUtil.copyFile(InstallerUtil.java:665)
        at com.cisco.hfr.cwi.installer.LocalCopyFileRetriever.copyFile(LocalCopyFileRetriever.java:143)
        at com.cisco.hfr.cwi.installer.CachedFile.init(CachedFile.java:60)
        at com.cisco.hfr.cwi.installer.LocalCopyFileRetriever.getFiles(LocalCopyFileRetriever.java:112)
        at com.cisco.hfr.cwi.installer.CacheUtilities.downloadToExistingCompat(CacheUtilities.java:280)
        at com.cisco.hfr.cwi.installer.CacheUtilities.downLoadRequiredFiles(CacheUtilities.java:307)
        at com.cisco.hfr.cwi.installer.CacheUtilities.updateCache(CacheUtilities.java:443)
        at com.cisco.hfr.cwi.installer.InstallerApplet.install(InstallerApplet.java:463)
        at com.cisco.hfr.cwi.installer.InstallerApplet.access$000(InstallerApplet.java:47)
        at com.cisco.hfr.cwi.installer.InstallerApplet$2.run(InstallerApplet.java:362)
        at java.lang.Thread.run(Unknown Source)
I'm running this jre:
C:\Users\testuser\Downloads\IOS-XR\CSM-2.0>java -version
java version "1.8.0_45"
Java(TM) SE Runtime Environment (build 1.8.0_45-b14)
Java HotSpot(TM) Client VM (build 25.45-b02, mixed mode)
Any advice on how to solve this would be appreciated.
David
0 Replies 0
