Difference between matches-every and matches-within
Hi everyone,
What is the difference between `matches-any` and `matches-within` in this context?
RP/0/RP0/CPU0:R6(config)#route-policy FOO
RP/0/RP0/CPU0:R6(config-rpl)#if community ?
  is-empty        Route has no BGP community attributes
  length          Length of BGP AS-path
  matches-any     At least one community from the route matches an element of a community set
  matches-every   Every element of a community set matches a community from the route
  matches-within  Every community from the route matches an element of a community set
Let's say my community-set BAR has these communities:
1:100
1:200
1:300
`if community matches-any` means "This route must have one of the communities in BAR to match"
`if community matches-every` means "This route must have all of these communities to match"
but what does `matches-within` mean?
Does it mean, "every community that this route has must be in the list BAR" ???
E.g. the following would pass
1.1.1.1/32 with 1:100, 1:200 and 1:300
But this would fail:
1.1.1.1/32 with 1:100, 1:200, 1:300 and 1:400 - just because 1:400 is not in BAR.
Is that correct?
Network Engineer
CCIE SP #69245
Your interpretation is correct.  For another example of "matches-within" RPL, see the A9K Command Ref:
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/routing/command/reference/b-routing-cr-asr9000/routing-policy-language-commands.html#wp4149428420
Disclaimers: I am long in CSCO. Bad answers are my own fault as they are not AI generated.
I dont sure your exmaple correct'
You mention BAR list' does within meaning any or every community list ?
I think within as I explained below is simply wildcard ANY.
community 1:100 2:100  3:100 4:200 5:300
match-any <<- any of community of above will match
match-every <<- all community of above must match
BUT what if I need to match only *:100 i.e. any community :100 here we use match-within (it like wildcard).
M02@rt37
Hello @steven.crutchley,
The "matches-any" keyword is used to specify that at least one community from the route being evaluated must match an element of a community set.
If any community from the route does not have a match within the community set, the condition would fail.
The "matches-within" keyword is used to specify that every community from the route being evaluated must match an element of a community set.
If there is at least one matching community, the condition would pass.
Best regards
