How to capture lldp packets?
How to capture LLDP packets?
Thank you very much.
mivens
You don't mention which platform you're using, but for the ASR9K, take a look at this Support Forums guide:
ASR9000/XR: How to use Port Spanning or Port Mirroring
You should be able to match LLDP traffic with a L2 ACL like this:
ethernet-services access-list LLDP 10 permit any any 0x88cc
Agreed that L2 ACL or SPAN would be easiest.
At the NP level we can look at show controller np counters and parse for LLDP, but that would only tell us if packets are coming in and getting punted or getting dropped. If they are getting dropped then we can do an NP capture to get the packets and dump the contents and convert to wireshark. The command on 5.3.x and greater is show controller np capture.
Sam
