How to check uptime in a card on an ASR1006
danieldores
How can you check the uptime of a card on an ASR1006?
We had ESP20 that was constantly crashing, yet the timers didn't change.
if you do a "show platform" It only shows the time when the card was installed in the chassis
Chassis type: ASR1006
Slot      Type                State                 Insert time (ago)
1         ASR1000-SIP10       ok                    2y24w
 1/0      SPA-5X1GE-V2        ok                    2y24w
 1/1      SPA-1XOC3-ATM-V2    ok                    2y24w
2         ASR1000-SIP10       ok                    2y24w
 2/0      SPA-5X1GE-V2        ok                    2y24w
 2/1      SPA-1XOC3-ATM-V2    ok                    2y24w
R0        ASR1000-RP2         ok, active            2y24w
R1        ASR1000-RP2         ok, standby           2y24w
F0        ASR1000-ESP20       ok, active            2y24w
F1        ASR1000-ESP20       ok, standby           3d23h
P0        ASR1006-PWR-DC      ok                    2y24w
P1        ASR1006-PWR-DC      ok                    2y24w
Slot      CPLD Version        Firmware Version
1         07091401            15.0(1r)S
2         07091401            15.0(1r)S
R0        08103002            15.0(1r)S
R1        08103002            15.0(1r)S
F0        08041102            15.0(1r)S
F1        08041102            15.0(1r)S
or
"show plat diag"
Slot: 1, ASR1000-SIP10
  Running state               : ok
  Internal state              : online
  Internal operational state  : ok
  Physical insert detect time : 00:00:46 (2y24w ago)
  Software declared up time   : 00:01:37 (2y24w ago)
  CPLD version                : 07091401
  Firmware version            : 15.0(1r)S
Sub-slot: 1/0, SPA-5X1GE-V2
  Operational status          : ok
  Internal state              : inserted
  Physical insert detect time : 00:00:38 (2y24w ago)
  Logical insert detect time  : 00:01:46 (2y24w ago)
Sub-slot: 1/1, SPA-1XOC3-ATM-V2
  Logical insert detect time  : 00:01:50 (2y24w ago)
Slot: 2, ASR1000-SIP10
  Running state               : ok
  Software declared up time   : 00:01:40 (2y24w ago)
Sub-slot: 2/0, SPA-5X1GE-V2
Sub-slot: 2/1, SPA-1XOC3-ATM-V2
  Physical insert detect time : 00:00:39 (2y24w ago)
  Logical insert detect time  : 00:01:54 (2y24w ago)
Slot: R0, ASR1000-RP2
  Running state               : ok, active
  Software declared up time   : 00:00:46 (2y24w ago)
  Became HA Active time       : 00:03:17 (2y24w ago)
  CPLD version                : 08103002
Slot: R1, ASR1000-RP2
  Running state               : ok, standby
  Software declared up time   : 00:01:31 (2y24w ago)
Slot: F0, ASR1000-ESP20
  Software declared up time   : 00:01:30 (2y24w ago)
  Hardware ready signal time  : 00:00:47 (2y24w ago)
  Packet ready signal time    : 00:01:46 (2y24w ago)
  Became HA Active time       : 2y23w (3d23h ago)
  CPLD version                : 08041102
Slot: F1, ASR1000-ESP20
  Physical insert detect time : 2y23w (3d23h ago)
  Software declared up time   : 2y23w (3d23h ago)
  Hardware ready signal time  : 2y23w (3d23h ago)
  Packet ready signal time    : 2y23w (3d23h ago)
Slot: P0, ASR1006-PWR-DC
  State                       : ok
  Physical insert detect time : 00:01:10 (2y24w ago)
Slot: P1, ASR1006-PWR-DC
  State                       : ok
  Physical insert detect time : 00:01:11 (2y24w ago)
What are the first and second timers exactly of this output?
Note: the timers only changed when we swapped  the ESP20 of the Slot F1
xthuijs
first of all congrats on the 2 and a half year uptime! :)
I see that one of the ESP's was inserted or up since 3 days, so that was the one that was crashing constantly?
the iffy part of uptime is that if you have redundant processors/cards etc, eg like RPR(+), the uptime doesnt reset when there is a RP failover.
That might be part of it.
ps this is the XROS forum, we focus here on mostly XR related products and sw. Not that you can't ask anything else, but our expertise is not in the XE area or ASR1000 series... just fyi :)
regards
xander
