How to do "default interface" on IOS XR?
vasilstoimenov
Hi Guys,
Does anybody know an equivalent of “default interface” for IOS XR or a smart way to delete hundreds of attachment circuits for single physical interface?
Appreciate your comments.
Vasil
Alexei Kiritchenko
Hello Vasil,
Use "no" with * to remove them.
For example we have gigabitEthernet 0/1/0/6 and we like to remove all the sub interfaces. Use "no gigabitEthernet 0/1/0/6.*"
To make the main config to default, use "no gigabitEthernet 0/1/0/6"
Before coming, you can use "show" to see what going to be removed:
RP/0/RSP0/CPU0:mercy(config)#no interface gigabitEthernet 0/1/0/6.*
RP/0/RSP0/CPU0:mercy(config)#show
Wed Oct 10 16:01:14.212 CEST
Building configuration...
!! IOS XR Configuration 4.2.1
no interface GigabitEthernet0/1/0/6.2
no interface GigabitEthernet0/1/0/6.3
end
/A
10x Alex, I was not aware of that, will try it.
Vasil
Bahaa J
do we need shutdown command after that ? thanks
Hi @Bahaa J ,
You just need to do "no interface gix/x/x/x.*" and then commit.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
