include ranges of QiQ vlans in interface
Kijush Maharjan
I need to encapsulate multiple QiQ vlans in a single interface. Initially, I used encapsulation ambiguous with stacked vlan but i wanted to add more outer vlan on same interface.
interface be1.1
encapsulation ambiguous dot1q 800 second-dot1q 100 , 120 , 140 , 160 , 180 , 1000 , 1100
Now i need to add another one in same interface.
encapsulation ambiguous dot1q 900 second-dot1q 200 , 220 , 240 , 260 , 280 , 2000 , 2100
How can i include both of theses as well as other outer clans in same interface? or need to create another sub interface?
Aleksandar Vidakovic
If you use the range in the first dot1q, you have to use 'any' on the second dot1q. Sub-interface classification is performed in HW, using TCAM. This makes the search very fast and of predictable duration.
Per one sub-interface you can have only a single line with encap config.
Use "sh ethernet hardware interface <interface> location <location>" to see how the TCAM was programmed to match on this interface.
