[ios pw redundancy with xr mc-lag termination]
Carlos A. Silva
Level 3
Level 3
hi, all:
first of all, thanks in advance and please take a look at the attached diagram.
i'm trying to setup a pseudowire redundancy setup between an ME3800 and two ASR9000s that build a mlacp etherchannel towards a cat4500, 4500-2. when primary pseudowire is up, everything works as expected. the problem is that, when you cause a switchover scenario from the primary asr9k-1 (say by shutting down the link to the 4500-2) to the secondary asr9k-2, traffic does not pass from one end of the pw to the other. if we bring up the failed link back up, primary pw works.
all 'show' commands checkout and pw switches over as expected. as a test, i have a 3rd asr9k connected in parallel to the ME3800 and we have no problem with that. when we cause the exact same failure scenario, the primary pw switches over to the secondary and everything works exactly like i would expect. traffic passes in both pri and stby pws when using the parallel asr9k.
as you will be able to see from attached-configs, the pw's from ME3800 and asr9k are a little different. ME3800 pw is port-based and asr9k pw is vlan-based, but since both primary pws work i see no obvious problem with that.
now, i know both ends of the mc-lag work, because the asr9k pw redundancy setup works.
if i build a single pw (no redundancy) from ME3800 to asr9k-1 connecivity works AND if i build a single pw from me3800 to asr9k-2 on same exact vlan, connecivity works also.
hopefully, one of you will take the time to look at configs and let me know if you see something wrong (i think with the ME3800 config). please keep in mind that everything works perfectly when working with asr9k pw redundancy (xr on both ends of pw)
c.
ME3800 (pw-redundancy)
3800#show run | section pseudowire
pseudowire-class mpls
encapsulation mpls
status peer topology dual-homed
! tried it without above status command, didn't work either.
3800#show run int g0/24
Building configuration...
Current configuration : 175 bytes
interface GigabitEthernet0/24
no switchport
no ip address
xconnect 207.x.y.9 1100 encapsulation mpls pw-class mpls
  backup peer 207.x.y.17 1101 pw-class mpls
end
3800#
3800#show xconnect all
Legend:    XC ST=Xconnect State  S1=Segment1 State  S2=Segment2 State
  UP=Up       DN=Down            AD=Admin Down      IA=Inactive
  SB=Standby  HS=Hot Standby     RV=Recovering      NH=No Hardware
XC ST  Segment 1                         S1 Segment 2                         S2
UP pri   ac Gi0/24:78(Ethernet)          UP mpls 207.x.y.9:1100            UP
IA sec   ac Gi0/24:78(Ethernet)          UP mpls 207.x.y.17:1101           DN
3800_sw_pruebas#
ASR-3 (pw-redundancy)
RP/0/RSP1/CPU0:ASR-3#show run l2vpn
Sat Jun 15 09:07:10.183 CST
l2vpn
xconnect group PRUEBAS-XXXX
  p2p ESC-MTZ
   interface Bundle-Ether1000.28
   neighbor 207.x.y.9 pw-id 1128
    backup neighbor 207.x.y.17 pw-id 1228
RP/0/RSP1/CPU0:ASR-3#show l2vpn xconnect
Sat Jun 15 09:20:26.183 CST
Legend: ST = State, UP = Up, DN = Down, AD = Admin Down, UR = Unresolved,
        SB = Standby, SR = Standby Ready
XConnect                   Segment 1                   Segment 2
Group      Name       ST   Description            ST   Description            ST
PRUEBAS-XXXX
           to4500-2    UP   BE1000.28              UP   207.x.y.9    1128   UP
                                                       Backup
                                                       207.x.y.17   1228   DN
asr9k-1  (pw-termination)
RP/0/RSP0/CPU0:asr9k-1#show run l2vpn
Sat Jun 15 09:09:10.555 CST
l2vpn
pw-status
pw-class mpls
  encapsulation mpls
   redundancy
    one-way
  p2p toASR-3
   neighbor 207.x.y.1 pw-id 1128
  p2p toME3800
   interface Bundle-Ether1000.26
   neighbor 207.x.y.30 pw-id 1100
RP/0/RSP0/CPU0:asr9k-1#show run redundancy
Sat Jun 15 09:09:16.659 CST
redundancy
iccp
  group 1000
   mlacp node 1
   mlacp system mac 000d.000e.000f
   mlacp system priority 1
   member
    neighbor 207.x.y.17
   backbone
RP/0/RSP0/CPU0:asr9k-2#show run l2vpn
Sat Jun 15 09:13:39.908 CST
l2vpn
pw-status
pw-class mpls
  encapsulation mpls
   redundancy
    one-way
  p2p toASR-3
   neighbor 207.x.y.1 pw-id 1228
  p2p toME3800
   neighbor 207.x.y.30 pw-id 1101
RP/0/RSP0/CPU0:asr9k-2#show run redundancy
Sat Jun 15 09:13:43.656 CST
redundancy
iccp
  group 1000
   mlacp node 2
   member
    neighbor 207.x.y.9
   backbone
xthuijs
hard to tell where and why the traffic gets dropped if I were to guess the me might send traff still down the wrong PW
due to mac learning so it might need to get flushed.
I thought however that as part of the pw switchover the mac flush is instantiated.
either case you want to set up a stream of say 1000 pps so it is easy to verify and check the np counters to see where and why these paks are getting dropped and if it is the 9k or the me in that regard.
suspect a pw signaling and mac flushing issue here.
xander
See the thing here is I'm sending traffic from the mc-lag side to the 3800. I actually see the counters increase (going in to) in the ME3800 but they never go out to the AC. At least that's what I think.
Since the all-ASR scenario works without problem, I'm assuming it's an ME3800 issue.
Interesting Carlos, you see it coming in on the right PW?
If that is the case then there is some internal switching issue inside the 3800 based on sig or something like that.
I dont know the me3800 well enough so I cant really tell you what commands to verify for this and you may have better luck handing this over to the ME3800 TAC support or the forum specific to that product.
cheers
xander
yup, coming into the right PW. i'll wait until tomorrow and might open a case.
thanks,
c.
