IOS XR 9001 IOS upgred
haytham.taymour
Hello all,
I want to install a new IOS on ASR 9001. I try to install it as below but it's not working. Currently it's running 6.5.3 with the below packages . Anyone can help please ?
Active Packages:
disk0:asr9k-mini-px-6.1.4
disk0:asr9k-k9sec-px-6.1.4
RP/0/RSP0/CPU0:ASR9001_CLS_02(admin)#install add harddisk:ASR9K-iosxr-px-k9-6.5.3.tar
Info: added to the entire router: Info: Info: README-ASR9K-iosxr-px-k9-6.5.3.txt (skipped - not a pie) Info: asr9k-video-px.pie-6.5.3 Info: asr9k-services-px.pie-6.5.3 Info: asr9k-services-infra-px.pie-6.5.3 Info: asr9k-optic-px.pie-6.5.3 Info: asr9k-mpls-px.pie-6.5.3 Info: asr9k-mini-px.pie-6.5.3 Info: asr9k-mgbl-px.pie-6.5.3 Info: asr9k-mcast-px.pie-6.5.3 Info: asr9k-li-px.pie-6.5.3 Info: asr9k-k9sec-px.pie-6.5.3 Info: asr9k-fpd-px.pie-6.5.3 Info: asr9k-doc-px.pie-6.5.3 Info: asr9k-bng-px.pie-6.5.3 Info: asr9k-asr9000v-nV-px.pie-6.5.3 Info: The install operation will continue asynchronously. RP/0/RSP0/CPU0:ASR9001_CLS_02(admin)#Error: The install operation failed due to a system error. Error: Error: ERROR: Node responded with an error when completing the installation of packages within the system. Error: (Details: 'Package Library' detected the 'fatal' condition 'can't uncompress pie archive') Error: AFFECTED NODE(S): 0/RSP0/CPU0 Error: TECH SUPPORT: Error: Please collect diagnostic information using '(admin) show tech-support install'
16 Replies 16
Since you have to upgrade all active packages to the new release at the same time it is failing, the package disk0:asr9k-asr901-nV-px-5.3.4 was deprecated as support for 901 satellite was removed. Simply deactivate that package and then the install should go through.
Sam
That definetly works like magic. Thanks smilstea and thanks for every one from Cisco and outside too.
This has been a wonderfull experince and I definely recommend and I would say way better then Cisco TAC.
Enjoy a lovely weekend beautiful team.
