IOS-XR_ASR9k_H-VPLS_with_MPLS_Access_Split_Horizon_Issue !
Vaibhava Varma
Level 4
Level 4
Dear All
I am working on a requirement to create a H-VPLS Setup with MPLS Access but am unable to get the setup working as the NPE is not able to send traffic received from other NPEs to the MPLS Access PW due to the Split-Horizon group being enabled by default for PW of same VFI.
After doing a lot of reading and digging am still unable to explore the option to disable split-horizon between the PWs of the same VFI. In IOS-XR I can not get anything equivalent to "neighbor 192.168.0.2 encapsulation mpls no-split-horizon" which I have configured at NPE3 to achieve communication between CE2 & CE4
Any pointers regarding this.Below is the setup for reference
                                    CE1----------AC-------------NPE1(ASR9k)
        xconnect
        VPLS
        NPE2(ASR9k)-----------------VPLS------------NPE3(IOS)--AC--CE3
        AC                                                            !
        CE2                                                           !
        -         VPLS-----NPE4(IOS)---AC---CE4
NOTE:
1.CE2 can reach CE1,CE3,CE4
2.CE3 can reach CE2,CE4 but not CE1
3.CE4 can reach CE2,CE3 but not CE1
Vaibhava Varma
xthuijs
yeah you cant disable split horizon in the vfi, it is the nature of the beast really.
IF you have HVPLS then your "access-pw's" need to be configured as if they are an AC, so outside the VFI.
You could, if you want to, move them to SHG2.
For more details on what SHG is where, you can check this message:
https://supportforums.cisco.com/message/3918240#3918240
regards
xander
xthuijs
regards
xander
Hi xander
I did come across that fact after some deep digging and the problem is now that my XR version does not supports access-pw under the bridge domain. I read more and found that H-VPLS is supported from XR 4.0 so now I will be upgrading the version.
Thanks for your insight into this issue.
Varma
Varma, aik yeah that is an old(er) release.
Access PW is configured like this and is available in all the "going" releases (xr423 or xr431 are the ones you probably
want to focus on)
RP/0/RSP0/CPU0:A9K-BNG(config)#l2vpn
RP/0/RSP0/CPU0:A9K-BNG(config-l2vpn)#bridge group test
RP/0/RSP0/CPU0:A9K-BNG(config-l2vpn-bg)#bridge-domain testing
RP/0/RSP0/CPU0:A9K-BNG(config-l2vpn-bg-bd)#neighbor ?
  A.B.C.D  IPv4 address of the peer
xander
