IOS-XR VRF Interface Loopback not in route
yllee1314
Have created an interface loopback and including it into vrf.
However the interface loppback will not appear when "show ip interface brief".
And I'm only able to ping vrf to interface loopback, unable to ping the route learnt in the vrf.
Following are the vrf configuration made:
prefix-set ABCD_Servers
192.168.100.0/24
end-set
route-policy ABCD_Servers
if destination in ABCD_Servers then
pass
endif
end-policy
vrf ABCD
address-family ipv4 unicast
import route-policy ABCD_Servers
import route-target
1234:12345
1234:6789
export route-target
1234:12345
router bgp 1234
vrf ABCD
rd 1234:12345
redistribute connected
interface Loopback800
vrf ABCD
ipv4 address 192.168.1.1 255.255.255.255
Olev Vallaste
Q.Have created an interface loopback and including it into vrf.
A.>>>
In IOS-XR slightly different command for output interfaces for all vrfs
Here is the needed command:
sho ipv4 vrf all interface brief
'show ip interface brief" command in IOS-XR shows only interfaces in default-vrf (GRT)
Q.And I'm only able to ping vrf to interface loopback, unable to ping the route learnt in the vrf.
A.>>>
Can you describe in more details, what ip-address you try to ping and from what source address?
A.>>>
Info>>>
Was trying to ping a server IP advertised in the vrf as below.
RP/0/RSP0/CPU0:PE-001#ping vrf ABCD 192.168.1.1
Mon Nov 23 09:57:25.573 GMT
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
RP/0/RSP0/CPU0:PE-001#show run int lo800
Mon Nov 23 09:57:42.711 GMT
vrf ABCD
RP/0/RSP0/CPU0:PE-001#ping vrf ABCD 192.168.100.58
Mon Nov 23 09:59:05.004 GMT
Sending 5, 100-byte ICMP Echos to 192.168.100.58, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
RP/0/RSP0/CPU0:PE-001#show route vrf ABCD
Fri Nov 20 23:08:11.834 GMT
Codes: C - connected, S - static, R - RIP, B - BGP, (>) - Diversion path
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
U - per-user static route, o - ODR, L - local, G - DAGR, l - LISP
A - access/subscriber, a - Application route
M - mobile route, (!) - FRR Backup path
Gateway of last resort is not set
B 192.168.100.0/24 [200/0] via x.x.x.4 (nexthop in vrf default), 03:43:50
L 192.168.1.1/32 is directly connected, 03:42:19, Loopback800
Hi, yllee1314
About "UUUUU" in ping output.
Is it 192.168.100.58 - host(server) or it is a router's interface?
Please provide 'sho route vrf ABCD 192.168.1.1' from router when network 192.168.100.0/24 resides.
Can you ping Gateway for 192.168.100.0/24 in vrf ABCD from PE-001 with source 192.168.1.1 ?
And please provide output from PE-001:
tracert vrf ABCD 192.168.100.58 source 192.168.1.1
tracert vrf ABCD <gw-ABCD-servers-ip-address> source 192.168.1.1
