ISM card stuck in MBI-running
cisco_lad2004
Level 5
Level 5
Dear all,
I am trying to bring up an ISM card installed on ASR9K running 4.2.1.
Card shows under inventory, but keeps pop in in and out of "show platform" as well between below 2 states:
0/2/CPU0        A9K-ISM-100(LCP)          IOS XR PREP      PWR,NSHUT,MON
And
0/2/CPU0        A9K-ISM-100(LCP)          MBI-RUNNING      PWR,NSHUT,MON
RP/0/RSP0/CPU0:CGN_PE#sh hw-module fpd location 0/2/CPU0
Wed Sep 26 16:13:04.966 CETDST
                                      Existing Field Programmable Devices
                                        HW                       Current SW Upg/
Location     Card Type                Version Type Subtype Inst   Version   Dng?
0/2/CPU0 does not exist
I tried reloading card few times after following procedures for fpd upgrade. I am beginiing to suspect fpd is corrupted.
Any thoughts ?
TIA
/Samir
22 Replies 22
Will do, many  thanks !
so thsi message, so tried below with no joy !
proc mandatory OFF fib_mgr location 0/2/CPU0
proc SHUTDOWN fib_mgr location 0/2/CPU0
RP/0/RSP0/CPU0:#admin
debug sim reload-disable location 0/2/CPU0
well...something has worked:
RP/0/RSP0/CPU0:CGN_PE#sh platform
Thu Sep 27 16:40:38.260 CETDST
Node            Type                      State            Config State
0/RSP0/CPU0     A9K-RSP440-SE(Active)     IOS XR RUN       PWR,NSHUT,MON
0/0/CPU0        A9K-MOD80-TR              IOS XR RUN       PWR,NSHUT,MON
0/0/0           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/2/CPU0        A9K-ISM-100(LCP)          IOS XR RUN       PWR,NSHUT,MON
0/2/CPU1        A9K-ISM-100(SE)           FAILED
Yes, after your shut down the fib manager on the card it does not reload the ISM due to the version incompatibility.
you may update PFD so far in order to prepare for the kit installation
(admin)#upgrade hw-module fpd all location 0/2/CPU0
/A
Thats right !
I did that already, then reloaded 0/2/CPU0 and it is still holding...so looking good so far.
Thanks again !
/Samir
TAC request sent, with subject :ISM card stuck in MBI-running. Cisco IOS XR  4.2.1 CGN
Summary:
The image has been provided to Sam but we could not deploy it.
We have found the CGN installation kit was corrupted. After re-downloading the package we could successfully deploy it.
Note: the image itself is a text script with binary together and starts as a text file. We suspect, FTP was detecting the image as TXT and hence working in text mode replacing new line and carrier return characters. Forcing FTP into binary mode we could successfully download it.
Advise is to verify MD5 checksum for downloaded SW
Thanks a million Alex, glad card is now ready to do what is supposed to. And yes, great advice, it could have saved me loads of valuable time :-)
Hello Samir,
I have a ISM module that cant come online, could help me with that? The problem happened before the ASR reloaded.
RP/0/RSP1/CPU0:router#admin show platform
Fri Nov  1 16:17:16.265 UTC
0/RSP0/CPU0     A9K-RSP440-TR(Standby)    IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP440-TR(Active)     IOS XR RUN       PWR,NSHUT,MON
0/FT0/SP        FAN TRAY                  READY
0/FT1/SP        FAN TRAY                  READY
0/0/CPU0        A9K-MOD160-TR             IOS XR RUN       PWR,NSHUT,MON
0/0/0           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/0/1           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/1/CPU0        A9K-MOD160-TR             IOS XR RUN       PWR,NSHUT,MON
0/1/0           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/1/1           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/3/CPU0        A9K-ISM-100(LCP)          IN-RESET         PWR,NSHUT,MON
0/3/SAM0        A9K-SAM-2TB               BOOTING          PWR,NSHUT,NMON
0/3/SAM1        A9K-SAM-2TB               FAILED           PWR,NSHUT,NMON
0/PM0/SP        PWR-3KW-AC-V2             READY            PWR,NSHUT,MON
0/PM1/SP        PWR-3KW-AC-V2             READY            PWR,NSHUT,MON
0/PM2/SP        PWR-3KW-AC-V2             READY            PWR,NSHUT,MON
LC/0/3/CPU0:Nov  1 16:16:11.475 : apiv_srvr[115]: %PLATFORM-APIV-3-MODULE_INCOMPATIBLE : APIV module APIV_SI is incompatible
LC/0/3/CPU0:Nov  1 16:16:11.697 : vkg_l2fib_mac_cache[340]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: initializing L2 FIB MAC CAHE APIV modules.
LC/0/3/CPU0:Nov  1 16:16:11.705 : /pkg/sbin/sysmgr_log[65661]: %OS-SYSMGR-7-CHECK_LOG : /pkg/bin/sysmgr_debug_script invoked for: (fib_mgr) process did not signal EOI and for level:100 . Output is in harddisk:/sysmgr_debug/debug.node0_3_CPU0.442485
LC/0/3/CPU0:Nov  1 16:16:11.801 : vkg_l2fib_mac_cache[340]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: retrieving SysDB notifications ...
LC/0/3/CPU0:Nov  1 16:16:11.801 : vkg_l2fib_mac_cache[340]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: Starting of L2FIB MAC CACHE APIV version negotiation.
LC/0/3/CPU0:Nov  1 16:16:13.624 : canb_upg_agt[132]: %PLATFORM-UPGRADE_FPD-4-DOWN_REV : cbc instance 0 is down-rev (V18.05), upgrade to (V18.08). Use the "upgrade hw-module fpd" CLI in admin mode.
LC/0/3/CPU0:Nov  1 16:16:14.119 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: Initializing L2 FIB APIV modules.
LC/0/3/CPU0:Nov  1 16:16:14.192 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: retrieving SysDB notifications.
LC/0/3/CPU0:Nov  1 16:16:14.192 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: starting of APIV version negotiation.
LC/0/3/CPU0:Nov  1 16:16:14.784 : avsm_se_sm[125]: %PLATFORM-SIM_SE-6-STATE_CHANGE : Service Engine is in shutting down state.
LC/0/3/CPU0:Nov  1 16:16:14.790 : sis[307]: %PLATFORM-VKG_SIS-6-GENERIC_EVENT : sis event: Starting of SI APIV Deletion ...
LC/0/3/CPU0:Nov  1 16:16:15.420 : apiv_srvr[115]: %PLATFORM-APIV-5-API_INCOMPATIBLE : Message 8 in APIV module ISM_L2FIB_APIV is incompatible (reason: Not supported on the remote side)
LC/0/3/CPU0:Nov  1 16:16:15.420 : apiv_srvr[115]: %PLATFORM-APIV-3-MODULE_INCOMPATIBLE : APIV module ISM_L2FIB_APIV is incompatible
LC/0/3/CPU0:Nov  1 16:16:16.421 : avsm_agent[124]: %ISM_L2_UFA-3-ERR :  L2UFA: apiv/ipcp init failed
LC/0/3/CPU0:Nov  1 16:16:21.641 : avsm_agent[124]: %SAM_OIR-3-SAM_ERR_FPD : SAM/1: Unable to initialize. Error in FPD of device(s):CPLD. Detailed message -23:Unable to connect to socket:/tmp/fpdinfra_socket  -23 111:Connection refused
RP/0/RSP1/CPU0:Nov  1 16:16:21.647 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/3/SAM1, state: FAILED
LC/0/3/CPU0:Nov  1 16:16:24.704 : fib_mgr[172]: %PLATFORM-PLAT_FIB-3-ERR_STR_NEGO_FAIL : CGN fib apiv ipcp init: Failed to negotiate the apiv version.: UNKNOWN (12293)
LC/0/3/CPU0:Nov  1 16:16:30.695 : fib_mgr[172]: %ROUTING-FIB-3-TABLE : table operation failed during Invalid table create failed: Resource temporarily unavailable  : pkg/bin/fib_mgr : (PID=434279) :  -Traceback= 4002b9cc 4001426c 40014630 400019f4 4ba73a44 4ba71554 400003f0 40014a78 4bada400
RP/0/RSP1/CPU0:Nov  1 16:16:37.142 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-ISM-100 state:IOS XR RUN
RP/0/RSP1/CPU0:Nov  1 16:16:37.144 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/3/CPU0, state: IOS XR RUN
LC/0/3/CPU0:Nov  1 16:16:47.370 : avsm_se_sm[125]: %PLATFORM-SIM_SE-6-STATE_CHANGE : Service Engine is in reset(Service Engine Software) state.
RP/0/RSP0/CPU0:Nov  1 16:16:47.418 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP0/CPU0:Nov  1 16:16:47.418 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , PLDREQ Sreset (0x0b000000)
RP/0/RSP1/CPU0:Nov  1 16:16:47.424 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP1/CPU0:Nov  1 16:16:47.424 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , PLDREQ Sreset (0x0b000000)
RP/0/RSP1/CPU0:Nov  1 16:16:47.425 : shelfmgr[387]: %PLATFORM-SHELFMGR-0-MAX_RESET_BRINGDOWN : Can not boot node 0/3/CPU0 A9K-ISM-100 due to multiple resets, putting it IN_RESET state. The probable cause is an unexpected event on the node or a failure in communication with the node. Please refer to the Cisco ASR 9000 System Error Message Reference Guide for further information if needed.
RP/0/RSP1/CPU0:Nov  1 16:16:47.425 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_CPU_RESET : Node 0/3/CPU0 CPU reset detected.
RP/0/RSP1/CPU0:Nov  1 16:16:47.427 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-ISM-100 state:IN-RESET
RP/0/RSP1/CPU0:Nov  1 16:16:47.434 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP0/CPU0:Nov  1 16:16:47.548 : ce_switch_srv[53]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 7 (LC_Slot_3) is down
RP/0/RSP1/CPU0:Nov  1 16:16:47.683 : ce_switch_srv[53]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 7 (LC_Slot_3) is down
RP/0/RSP1/CPU0:Nov  1 16:16:48.436 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP1/CPU0:Nov  1 16:16:50.437 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP1/CPU0:Nov  1 16:16:54.439 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
Thanks in advance,
Renato
