07-24-2013 08:07 PM
Hello everyone,
I'm trying to set up NAT44 in the following scenario below and I'm having a hard time figuring out how to redirect the traffic. As you can see the big problem is that I have one single interface that connects to the internal network (10.0.0.0/8) and also to the tunnel destinations all in the same VRF. Can you guys give me a hand? The trafiic comes from network network 10.0.0.0/8 enters interface bundle-ether 2 (Now it needs to be translated), once it is translated, now it needs to reach the destination known via GRE tunnel.
Configurations
vrf NAT_IN
address-family ipv4 unicast
vrf BLUE
hw-module service cgn location 0/3/CPU0
interface Bundle-Ether2
description UPLINK TO METRO ETHERNET
interface Bundle-Ether2.2 l2transport
encapsulation dot1q 2
rewrite ingress tag pop 1 symmetric
interface GigabitEthernet200/0/0/43
description LINK TO METRO ETHERNET
bundle id 2 mode active
interface GigabitEthernet300/0/0/43
interface BVI2
description METRO
vrf BLUE
ipv4 address 100.0.0.10/24
interface tunnel-ip 101
description GRE_TUNNEL
vrf BLUE
ipv4 address 1.1.1.1/32
tunnel mode gre ipv4
tunnel source interface bvi 2
tunnel destination 200.0.0.1
interface BVI 100
vrf BLUE
ipv4 address [GATEWAY_100] [MASK_100]
interface BVI 200
vrf BLUE
ipv4 address [GATEWAY_200] [MASK_200]
interface BVI 300
vrf BLUE
ipv4 address [GATEWAY_300] [MASK_300]
interface ServiceApp1
vrf NAT_IN
ipv4 address 10.0.2.1 255.255.255.252
service cgn CGN service-type nat44
interface ServiceApp2
vrf BLUE
ipv4 address 10.0.2.2 255.255.255.252
interface ServiceInfra1
ipv4 address 10.0.3.1 255.255.255.0
service-location 0/3/CPU0
router static
vrf NAT_IN
0.0.0.0/0 ServiceApp1
10.0.0.0/8 vrf BLUE bvI 2 <NEXT HOP>
vrf BLUE
172.16.0.0/24 ServiceApp2
router ospf METRO
vrf BLUE
router-id [ROUTER_ID]
redistribute bgp 65500 metric 100
area 0
interface bvi 2
router ospf BLUE
vrf BLUE
router-id [ROUTER ID]
area 10
interface BVI100
interface BVI200
interface BVI200
router bgp 65500
address-family vpnv4 unicast
vrf BLUE
rd 65500:2
redistribute static
redistribute ospf BLUE
neighbor 1.1.1.2
remote-as 64512
ebgp-multihop 5
route-policy PASS in
route-policy PASS out
service cgn CGN
service-location preferred-active 0/3/CPU0
service-type nat44 nat44
portlimit 20000
inside-vrf NAT_IN
map outside-vrf BLUE address-pool 172.16.0.0/24
Thanks in advance,
Renato
Solved! Go to Solution.
08-21-2013 04:04 AM
One more question - Can I ask who is the customer here and also are you part of the customer organization or some other partner organization who is helping customer ?
08-21-2013 09:07 AM
Hi Renato,
Congratulations. You are very welcome. Let us know if you have any additional questions or concerns.
09-20-2013 08:31 AM
Hi Somnath.
I will post the configuration as soon as possible. I would like to know if is there any command to check what is the current version of the linux I'm using on the ISM module?
Thanks in advance,
Renato Reis
09-20-2013 09:09 AM
Hi Renato,
You can use "show platform summary location
regards,
Somnath.
09-20-2013 10:48 AM
Thank you Somnath,
I'm still confused if the version that is being shown in the output below (IOS SW Ver : 4.3.1) is related to the linux kit or the IOS-XR itself.
:router#show platform summary location 0/3/CPU0
Fri Sep 20 17:45:50.010 UTC
Platform Node : 0/3/CPU0 (slot 5)
PID : A9K-ISM-100
Card Type : Integrated Services Module
VID/SN : V01 / FOC1710N5NX
Oper State : IOS XR RUN
Last Reset : N/A
: N/A
Configuration : Power is enabled
Bootup enabled.
Monitoring enabled
Rommon Ver : Version 1.2(20091201:235620)
IOS SW Ver : 4.3.1
Main Power : Power state Enabled. Estimate power 405 Watts of power required.
Faults : N/A
Platform Node : 0/3/CPU1 (slot 5)
Card Type : Integrated Services Module (Service Engine)
Oper State : APP-READY
Last Start Time : Sun Sep 8 18:20:55 2013
Last Ready Time : Sun Sep 8 19:53:01 2013
Uptime : 285:52:49
BIOS Ver : 0.17 (Thurley.3.60.18.0033)
SW Ver : 1.0.1.0 (Built on May 3, 2012, from services/cgn@r421-support/7)
App Status : 8 CGv6 Application instance(s) is/are running
:router#
[]'s
Renato Reis
09-20-2013 09:11 PM
Hi Renato,
We need to look at "CPU1" status as that is the Application CPU. "CPU0" is the XR CPU.
I see -
This gives the Application s/w version.
It looks like you need to upgrade the Linux part (install-kit) to 4.3.1. (it is running 421 now).
Procedure to upgrade the install-kit is in CCO.
regards,
Somnath.
09-21-2013 02:52 PM
Hello Somnath,
I'm so sorry I didn't see that...thank you again !
Renato
10-29-2013 10:40 AM
Hi guys, It`s me again !
Could you guys help me with an ISM module stuck in the BRINGDOWN state?
RP/0/RSP0/CPU0:router#admin show platform
Tue Oct 29 10:34:32.782 UTC
Node Type State Config State
0/RSP0/CPU0 A9K-RSP440-TR(Active) IOS XR RUN PWR,NSHUT,MON
0/RSP1/CPU0 A9K-RSP440-TR(Standby) IOS XR RUN PWR,NSHUT,MON
0/FT0/SP FAN TRAY READY
0/FT1/SP FAN TRAY READY
0/0/CPU0 A9K-MOD160-TR IOS XR RUN PWR,NSHUT,MON
0/0/0 A9K-MPA-8X10GE OK PWR,NSHUT,MON
0/0/1 A9K-MPA-8X10GE OK PWR,NSHUT,MON
0/1/CPU0 A9K-MOD160-TR IOS XR RUN PWR,NSHUT,MON
0/1/0 A9K-MPA-8X10GE OK PWR,NSHUT,MON
0/1/1 A9K-MPA-8X10GE OK PWR,NSHUT,MON
0/3/CPU0 A9K-ISM-100(LCP) BRINGDOWN PWR,NSHUT,MON
0/PM0/SP PWR-3KW-AC-V2 READY PWR,NSHUT,MON
0/PM1/SP PWR-3KW-AC-V2 READY PWR,NSHUT,MON
0/PM2/SP PWR-3KW-AC-V2 READY PWR,NSHUT,MON
Thank you in advance,
Renato Reis
10-29-2013 11:03 AM
Hi Renato,
How did it come to this stage ? Were you installing / upgrading the s/w ?
If so, you can refer to / follow some of the steps mentioned under http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.3/cg_nat/configuration/guide/cgnat43cgn.html#wp1015556.
regards,
Somnath.
10-29-2013 11:32 AM
Hi Somnath,
Actually it was right after a power outage...
Renato Reis
10-29-2013 08:35 PM
Hi Renato,
Ok. In that case, as a recovery, you may want to try "hw-module reload loc
Can you please provide "sh logging" output which possibly would give more details on the issue(s) faced by the card ?
regards,
Somnath.
10-30-2013 02:35 AM
Hi Somnath,
I've opened a TAC and they recommended R|MA for this module, thank you for you attention.
Renato
11-01-2013 11:22 AM
Hi Somnath,
We replaced the module but the new one cant boot up either, here is the log message and the current state of the ISM module.
RP/0/RSP1/CPU0:router#admin show platform
Fri Nov 1 16:17:16.265 UTC
0/RSP0/CPU0 A9K-RSP440-TR(Standby) IOS XR RUN PWR,NSHUT,MON
0/RSP1/CPU0 A9K-RSP440-TR(Active) IOS XR RUN PWR,NSHUT,MON
0/3/CPU0 A9K-ISM-100(LCP) IN-RESET PWR,NSHUT,MON
0/3/SAM0 A9K-SAM-2TB BOOTING PWR,NSHUT,NMON
0/3/SAM1 A9K-SAM-2TB FAILED PWR,NSHUT,NMON
LC/0/3/CPU0:Nov 1 16:16:11.475 : apiv_srvr[115]: %PLATFORM-APIV-3-MODULE_INCOMPATIBLE : APIV module APIV_SI is incompatible
LC/0/3/CPU0:Nov 1 16:16:11.697 : vkg_l2fib_mac_cache[340]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: initializing L2 FIB MAC CAHE APIV modules.
LC/0/3/CPU0:Nov 1 16:16:11.705 : /pkg/sbin/sysmgr_log[65661]: %OS-SYSMGR-7-CHECK_LOG : /pkg/bin/sysmgr_debug_script invoked for: (fib_mgr) process did not signal EOI and for level:100 . Output is in harddisk:/sysmgr_debug/debug.node0_3_CPU0.442485
LC/0/3/CPU0:Nov 1 16:16:11.801 : vkg_l2fib_mac_cache[340]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: retrieving SysDB notifications ...
LC/0/3/CPU0:Nov 1 16:16:11.801 : vkg_l2fib_mac_cache[340]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: Starting of L2FIB MAC CACHE APIV version negotiation.
LC/0/3/CPU0:Nov 1 16:16:13.624 : canb_upg_agt[132]: %PLATFORM-UPGRADE_FPD-4-DOWN_REV : cbc instance 0 is down-rev (V18.05), upgrade to (V18.08). Use the "upgrade hw-module fpd" CLI in admin mode.
LC/0/3/CPU0:Nov 1 16:16:14.119 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: Initializing L2 FIB APIV modules.
LC/0/3/CPU0:Nov 1 16:16:14.192 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: retrieving SysDB notifications.
LC/0/3/CPU0:Nov 1 16:16:14.192 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: starting of APIV version negotiation.
LC/0/3/CPU0:Nov 1 16:16:14.784 : avsm_se_sm[125]: %PLATFORM-SIM_SE-6-STATE_CHANGE : Service Engine is in shutting down state.
LC/0/3/CPU0:Nov 1 16:16:14.790 : sis[307]: %PLATFORM-VKG_SIS-6-GENERIC_EVENT : sis event: Starting of SI APIV Deletion ...
LC/0/3/CPU0:Nov 1 16:16:15.420 : apiv_srvr[115]: %PLATFORM-APIV-5-API_INCOMPATIBLE : Message 8 in APIV module ISM_L2FIB_APIV is incompatible (reason: Not supported on the remote side)
LC/0/3/CPU0:Nov 1 16:16:15.420 : apiv_srvr[115]: %PLATFORM-APIV-3-MODULE_INCOMPATIBLE : APIV module ISM_L2FIB_APIV is incompatible
LC/0/3/CPU0:Nov 1 16:16:16.421 : avsm_agent[124]: %ISM_L2_UFA-3-ERR : L2UFA: apiv/ipcp init failed
LC/0/3/CPU0:Nov 1 16:16:21.641 : avsm_agent[124]: %SAM_OIR-3-SAM_ERR_FPD : SAM/1: Unable to initialize. Error in FPD of device(s):CPLD. Detailed message -23:Unable to connect to socket:/tmp/fpdinfra_socket -23 111:Connection refused
RP/0/RSP1/CPU0:Nov 1 16:16:21.647 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/3/SAM1, state: FAILED
LC/0/3/CPU0:Nov 1 16:16:24.704 : fib_mgr[172]: %PLATFORM-PLAT_FIB-3-ERR_STR_NEGO_FAIL : CGN fib apiv ipcp init: Failed to negotiate the apiv version.: UNKNOWN (12293)
LC/0/3/CPU0:Nov 1 16:16:30.695 : fib_mgr[172]: %ROUTING-FIB-3-TABLE : table operation failed during Invalid table create failed: Resource temporarily unavailable : pkg/bin/fib_mgr : (PID=434279) : -Traceback= 4002b9cc 4001426c 40014630 400019f4 4ba73a44 4ba71554 400003f0 40014a78 4bada400
RP/0/RSP1/CPU0:Nov 1 16:16:37.142 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-ISM-100 state:IOS XR RUN
RP/0/RSP1/CPU0:Nov 1 16:16:37.144 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/3/CPU0, state: IOS XR RUN
LC/0/3/CPU0:Nov 1 16:16:47.370 : avsm_se_sm[125]: %PLATFORM-SIM_SE-6-STATE_CHANGE : Service Engine is in reset(Service Engine Software) state.
RP/0/RSP0/CPU0:Nov 1 16:16:47.418 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP0/CPU0:Nov 1 16:16:47.418 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , PLDREQ Sreset (0x0b000000)
RP/0/RSP1/CPU0:Nov 1 16:16:47.424 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP1/CPU0:Nov 1 16:16:47.424 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , PLDREQ Sreset (0x0b000000)
RP/0/RSP1/CPU0:Nov 1 16:16:47.425 : shelfmgr[387]: %PLATFORM-SHELFMGR-0-MAX_RESET_BRINGDOWN : Can not boot node 0/3/CPU0 A9K-ISM-100 due to multiple resets, putting it IN_RESET state. The probable cause is an unexpected event on the node or a failure in communication with the node. Please refer to the Cisco ASR 9000 System Error Message Reference Guide for further information if needed.
RP/0/RSP1/CPU0:Nov 1 16:16:47.425 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_CPU_RESET : Node 0/3/CPU0 CPU reset detected.
RP/0/RSP1/CPU0:Nov 1 16:16:47.427 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-ISM-100 state:IN-RESET
RP/0/RSP1/CPU0:Nov 1 16:16:47.434 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP0/CPU0:Nov 1 16:16:47.548 : ce_switch_srv[53]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 7 (LC_Slot_3) is down
RP/0/RSP1/CPU0:Nov 1 16:16:47.683 : ce_switch_srv[53]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 7 (LC_Slot_3) is down
RP/0/RSP1/CPU0:Nov 1 16:16:48.436 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP1/CPU0:Nov 1 16:16:50.437 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP1/CPU0:Nov 1 16:16:54.439 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
Renato Reis
11-01-2013 08:38 PM
Hi Renato,
Couple of things:
regards,
Somnath.
11-02-2013 05:57 AM
Hi Somnath,
I guess the ISM's software version is up to date. How can I disadle the SAM modules?
RP/0/RSP1/CPU0:router#admin show platform summary location 0/3/CPU0
Sat Nov 2 10:57:05.277 UTC
PID : A9K-ISM-100
VID/SN : V01 / FOC151984LQ
Oper State : IN-RESET
Last Reset : N/A
: N/A
Bootup enabled.
Monitoring enabled
IOS SW Ver : 4.3.2
Main Power : Power state Disabled.
Faults : N/A
RP/0/RSP1/CPU0:router#admin show install active summary
Sat Nov 2 10:57:11.659 UTC
Default Profile:
SDRs:
Owner
Active Packages:
disk0:asr9k-mini-px-4.3.2
disk0:asr9k-9000v-nV-px-4.3.2
disk0:asr9k-doc-px-4.3.2
disk0:asr9k-fpd-px-4.3.2
disk0:asr9k-k9sec-px-4.3.2
disk0:asr9k-mgbl-px-4.3.2
disk0:asr9k-mpls-px-4.3.2
disk0:asr9k-services-px-4.3.2
LC/0/3/CPU0:Nov 1 17:24:54.895 : avsm_agent[124]: %PROCMGR-3-PROCESS_CRASH : process avsm_sia crashed, restarting it...
LC/0/3/CPU0:Nov 1 17:24:54.896 : avsm_agent[124]: %PROCMGR-2-SE_RESTART : process avsm_sia restart too many times, Service Engine is going to reboot.
LC/0/3/CPU0:Nov 1 17:24:54.959 : apiv_srvr[115]: %PLATFORM-APIV-5-API_INCOMPATIBLE : Message 24 in APIV module APIV_SI is incompatible (reason: Not supported on the remote side)
LC/0/3/CPU0:Nov 1 17:24:54.959 : apiv_srvr[115]: %PLATFORM-APIV-3-MODULE_INCOMPATIBLE : APIV module APIV_SI is incompatible
LC/0/3/CPU0:Nov 1 17:24:56.642 : canb_upg_agt[132]: %PLATFORM-UPGRADE_FPD-4-DOWN_REV : cbc instance 0 is down-rev (V18.05), upgrade to (V18.08). Use the "upgrade hw-module fpd" CLI in admin mode.
LC/0/3/CPU0:Nov 1 17:24:57.241 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: Initializing L2 FIB APIV modules.
LC/0/3/CPU0:Nov 1 17:24:57.313 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: retrieving SysDB notifications.
LC/0/3/CPU0:Nov 1 17:24:57.313 : l2fib[239]: %PLATFORM-PLAT_L2FIB-6-GENERIC : avsm l2fib: starting of APIV version negotiation.
LC/0/3/CPU0:Nov 1 17:24:58.033 : avsm_se_sm[125]: %PLATFORM-SIM_SE-6-STATE_CHANGE : Service Engine is in shutting down state.
LC/0/3/CPU0:Nov 1 17:24:58.035 : sis[307]: %PLATFORM-VKG_SIS-6-GENERIC_EVENT : sis event: Starting of SI APIV Deletion ...
LC/0/3/CPU0:Nov 1 17:24:58.840 : apiv_srvr[115]: %PLATFORM-APIV-5-API_INCOMPATIBLE : Message 8 in APIV module ISM_L2FIB_APIV is incompatible (reason: Not supported on the remote side)
LC/0/3/CPU0:Nov 1 17:24:58.840 : apiv_srvr[115]: %PLATFORM-APIV-3-MODULE_INCOMPATIBLE : APIV module ISM_L2FIB_APIV is incompatible
LC/0/3/CPU0:Nov 1 17:24:59.842 : avsm_agent[124]: %ISM_L2_UFA-3-ERR : L2UFA: apiv/ipcp init failed
LC/0/3/CPU0:Nov 1 17:25:05.063 : avsm_agent[124]: %SAM_OIR-3-SAM_ERR_FPD : SAM/1: Unable to initialize. Error in FPD of device(s):CPLD. Detailed message -23:Unable to connect to socket:/tmp/fpdinfra_socket -23 111:Connection refused
RP/0/RSP1/CPU0:Nov 1 17:25:05.065 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/3/SAM1, state: FAILED
LC/0/3/CPU0:Nov 1 17:25:07.897 : fib_mgr[172]: %PLATFORM-PLAT_FIB-3-ERR_STR_NEGO_FAIL : CGN fib apiv ipcp init: Failed to negotiate the apiv version.: UNKNOWN (12293)
LC/0/3/CPU0:Nov 1 17:25:13.838 : fib_mgr[172]: %ROUTING-FIB-3-TABLE : table operation failed during Invalid table create failed: Resource temporarily unavailable : pkg/bin/fib_mgr : (PID=442471) : -Traceback= 4002b9cc 4001426c 40014630 400019f4 4ba73a44 4ba71554 400003f0 40014a78 4bada400
RP/0/RSP1/CPU0:Nov 1 17:25:20.654 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-ISM-100 state:IOS XR RUN
RP/0/RSP1/CPU0:Nov 1 17:25:20.656 : invmgr[257]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/3/CPU0, state: IOS XR RUN
LC/0/3/CPU0:Nov 1 17:25:32.631 : avsm_se_sm[125]: %PLATFORM-SIM_SE-6-STATE_CHANGE : Service Engine is in reset(Service Engine Software) state.
RP/0/RSP1/CPU0:Nov 1 17:25:32.678 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP1/CPU0:Nov 1 17:25:32.678 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , PLDREQ Sreset (0x0b000000)
RP/0/RSP1/CPU0:Nov 1 17:25:32.678 : shelfmgr[387]: %PLATFORM-SHELFMGR-0-MAX_RESET_BRINGDOWN : Can not boot node 0/3/CPU0 A9K-ISM-100 due to multiple resets, putting it IN_RESET state. The probable cause is an unexpected event on the node or a failure in communication with the node. Please refer to the Cisco ASR 9000 System Error Message Reference Guide for further information if needed.
RP/0/RSP1/CPU0:Nov 1 17:25:32.679 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_CPU_RESET : Node 0/3/CPU0 CPU reset detected.
RP/0/RSP0/CPU0:Nov 1 17:25:32.681 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Cycle (0x05000000)
RP/0/RSP0/CPU0:Nov 1 17:25:32.681 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , PLDREQ Sreset (0x0b000000)
RP/0/RSP1/CPU0:Nov 1 17:25:32.681 : shelfmgr[387]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/3/CPU0 A9K-ISM-100 state:IN-RESET
RP/0/RSP1/CPU0:Nov 1 17:25:32.689 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP1/CPU0:Nov 1 17:25:32.702 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Off (0x0a000000)
RP/0/RSP0/CPU0:Nov 1 17:25:32.705 : canb-server[149]: %PLATFORM-CANB_SERVER-7-CBC_PRE_RESET_NOTIFICATION : Node 0/3/CPU0 , Power Off (0x0a000000)
RP/0/RSP0/CPU0:Nov 1 17:25:32.917 : ce_switch_srv[53]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 7 (LC_Slot_3) is down
RP/0/RSP1/CPU0:Nov 1 17:25:32.922 : ce_switch_srv[53]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 7 (LC_Slot_3) is down
RP/0/RSP1/CPU0:Nov 1 17:25:33.691 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP1/CPU0:Nov 1 17:25:35.693 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
RP/0/RSP1/CPU0:Nov 1 17:25:39.694 : mibd_entity[324]: %HA-HA_EM-7-FMFD_CONNECTION_FAIL : Could not connect to /dev/fm/fd_wdsysmon.d/node0_3_CPU0 : No such file or directory
Renato
