Hi!
I Have a CRS-8 with 10 downlinks. All the 10 downlinks are operational. I have configured 10 static routes to the same IP destination pointing to these 10 links for redundancy and balancing. The static routes are pointing to the IP next-hop and the router does a recursive lookup.
But, by default, just 4 of 10 have been installed on the routing table. Is it possible to modify this default behaviour? I'd like to increase the number of paths for load-balancing. Is there any impact on the performance?
Thanks!
