Load sharing in CISCO 12000 XR
Hi All,
How can I change the load sharing algoritham to per-packet in 12000 GSR IOS XR 4.0.1
Arun Mohan
Anilkumar Dantu
    you can use below command to acheive  load balancing across equal cost links.
cef load-balancing fields L3/L4                         ###L3 is default
Anilkumar Dantu
sheetal.saxena1
I have been informed that per packet load balancing does not work in CISCO 12000 GSR IOS XR
and even link bundling does not work properly.
