Is it possible to enable ip load-sharing per-packet on Cisco 4k router (ISR4331 for example)? I work for one Telecom operator, and we need to change the existing Cisco 1921 routers with the new ISR 4K. Some of the users use SHDSL.bis load-balancing for distribution of the traffic, and for such customer we should provide the load-balancing per-packet. I have tried to configure ISR4331 in our test environment, but I find that I could only configure load-sharing per-destination. Also, I couldn't disable the ip route-cache on an interface (also I need that..).
