mLACP ASR9K, ICCP GROUP system mac
Javier Campos
Cual es la diferencia entre estos parámetros?
Step 3
mlacp system mac mac-id
Example:
RP/0/RSP0/CPU0:router#(config-redundancy-iccp-group) # mlacp system mac 1.1.1
Configures the LACP system ID to be used in this ICCP Group.
Note http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifThe mac-id is a user configured value for the LACP system LAG-ID to be used by the POAs. It is highly recommended that the mac-ids have the same value on both POAs. You can have different LAG-IDs for different groups.
Step 3
mac-address mac-id
Example:
RP/0/RSP0/CPU0:router#(config-if)# mac-address 1.1.1
Sets the MAC address on the interface.
Note http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifConfiguring the same MAC address on both POAs is highly recommended.
Es necesario definir ambos para la configuración de CE's DHD (Dual Home Device) o basta solo con uno?
Agradecido¡
JC
Carlos A. Silva
Level 3
Level 3
Mlacp system mac es el identificador que usan un par de chassises en conjunto para negociar lacp contra el DHD.
El comando de MAC sería para la interface Bundle, correcto? Cisco recomienda igualarla en ambos PoAs.
https://supportforums.cisco.com/document/9868751/asr9000xr-multichassis-lag-or-mc-lag-mclag-guide
Carlos A. Silva
Level 3
Level 3
