MPLS l2 vfi MTU not reached 1500
NOC_Infonet
HI all,
I have faced MTU issue in MPLS L2 vfi tunnel.
End A
l2 vfi VLAN2559 manual
vpn id 2559
bridge-domain 2559
mtu 9180
neighbor 192.168.100.10 encapsulation mpls
interface BDI2559
ip vrf forwarding cisco
ip address 192.168.10.1 255.255.255.252
End-B
vpn id 2559
bridge-domain 2559
mtu 9180
neighbor 192.168.100.49 encapsulation mpls
interface BDI2559
ip address 192.168.10.2 255.255.255.252
Router(config)#do ping vrf sify 192.168.10.1
Sending 5, 100-byte ICMP Echos to 192.168.10.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/21/24 ms
Router(config)#do ping vrf sify 192.168.10.1 size 1500
Sending 5, 1500-byte ICMP Echos to 192.168.10.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Kindly verify the above mention the log What should go wrong? Please help.
simple answer your SP is not accept value 1500 you must reduce it with at least 24 bytes (assume there will be three label add to frame).
Please kindly explain briefly.
your SP Core can support only standard Frame which is 1518-1522,
and you push traffic 1500 before add MPLS labels then the traffic  will drop
you must reduce the traffic you push to be + MPLS labels less than 1518-1522 value.
command you can use to set the correct value is
MPLS MTU
and you can see the MTU use by SP by
show mpls forwarding-table detail
smilstea
MTU configured in the BD is just for signalling, you would have to configure MTU on the ACs / physical interfaces for the MTU to change. At least that is the case for XR (the board where this post was posted).
Sam
